internal fuse box location c class
andrewjohn
hereford
2013 c 220 diesel estate type 204 k
I have a 2013 c class 220 estate. The interior fuse box should be under a plastic panel on the side of the dash by the A post. I have a slot but there is no fuse box??? Mercedes don't have an answer. Any clues???
Should it be at the other side.
C350Carl
Middle East
BMW 740Ld xDrive
It is on the offside (drivers side) rear panel in the boot on the estates. Behind where the first aid kit normally fits etc
A
andrewjohn
hereford
fuse box
Not on either side of the dash. covers come off ok. Drivers side has a slot where it looks like it should be as in the pic. Passenger side has nothing, fuse boxes in the boot and under the bonnet are clear. just the one that should be on the side of the dash is missing.
C350Carl
Middle East
BMW 740Ld xDrive
You don't get both on the estate. I never had one in the dash on my C350 despite what the manual said. You only get two total. One in the boot and one in the engine bay.
A
andrewjohn
hereford
Thanks so much. Better service than Mercedes UK!!!!!! I am wiring in a dash cam. I have located an ignition feed on the boot fusebox. I can either use this; or run a sub fused supply from the centre console auxilary 12v feed.
Again thanks so much for the prompt response.
C350Carl
Middle East
BMW 740Ld xDrive
Just be careful. I had issues wiring my dashcam as Mercedes employ a stepped sleep system.
So some fuses switch off after 60mins and some after 90mins. I can't remember the exact fuse location I used for the permanent live. So if you have a voltage tester unlock the car, then leave all well alone for 2hrs. Do all your cable routing etc and have brew or 6. Don't touch the keys and you should then find a permanent live feed.
Failing that if the battery is in the boot as it was on my C350 then you could take the permanent live from the positive terminal.
umblecumbuz
Wales and Gozo
As above.
Easy live feed on the C class estates from the battery under the boot floor, routed through the offside cavity where a fusible link can be fitted and tethered beside the rear fusebox.
Umble
Sarah007
New Registration
C 220 CDI 2014
Hi all! Does anyone know where is the fuse box on a C 220 CDI 2014? We’ve found two one in the boot and other where the engine is. But some places say it has two and others say it has 3 inside the car passengers side.. As we’ve just replaced the main headlights and they still won’t turn on.. we think it maybe the fuse..
Srdl
Hampshire
GLC43 AMG 2018 (X253)
Have a look at this site. On a UK car it should be at the right hand end (driver's side) of the dashboard.
https://fuse-box.info/mercedes-benz/mercedes-benz-c-class-w204-2008-2014-fuses-and-relay
onefortheroad
uk.
If its got memory seats , look either end of the dash .
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
These are the fuse locations on a W 204 1-36 and 123 are LHD/RHD locations
