K&N air Filter for CLC is it worth extra cost ?
Nikki2512
Gerrards cross bucks
CLC 220 CDI sport 2008, C200 Sport Estate 205 series 2015
Hi
The K&N publicity leads you to understand that their air filters improve performance and are a real improvement. Are they worth fitting or should I stick with the Mercedes OEM air filter.
I have a CLC 220CDI and the K&N filter that should fit as far as I can see is
E-2018 at best cost £555-85 from DemonTweekDirect online.
Any thoughts and advise from the owners who know and have been here before.
Thanks. Nikki
Craiglxviii
Cambs UK
No, placebo effect only. Won't do a thing unless your engine is remapped for much greater breathing requirements. Stick with standard filters.
Agree with Craig, I had K&Ns on my SL500 and it didn't make any performance difference at all, it did change the engine note to a more aggressive tone though.
That could be reason enough for you of course !
Oh and I assume you mean 55.85 not 555.85!
Try Euro car parts if you're set on buying them or K & N direct
Yugguy
Rugby, UK
C220CDI W204 Elegance Comand
20 quid for a genuine mb air filter on a c220, just change it every 10k.
K&N are a marketing success story.
They will have you believe their filters filter better and flow more air and do the clog as quickly. These are competing and conflicting requirements.
The job of a filter is extract dirt from air so if it 'clogs' it's doing its job. The only way you increase airflow without compromising filtering is to increase surface area. Given an air box is a fixed volume there is very little opportunity to increase surface area without creating flow issues elsewhere.
There have been numerous tests on filtration performance of various filters and in virtually all cases the paper element filters comes out tops.
Test for flow slow a marginal improvement with K&N filters but not enough to be noticeable (and no more than you'd get between different brands of stock air filters).
K&N filters are cleanable and reusable but frankly I'd rather know the filter I put on was as close to spotless as possible rather than worry about and dirt being washed through where it could be drawn into the engine. A washed filter also needs reoiling which if not done correctly can cause oil deposits on the MAF sensor. A MAF is far more expensive than an air filter!
In short for most people it's a waste of money.
britnordic
Cambridge
2006 SLK 200 & 2013 E Class 220
I had a K&N on a C estate 220 cdi, noise was better and that's all!
Never fitted one again, standard filter is best, no brainer imho
Tony
B
brick10
I have had K&N filters on cars in the past and i think they are a waste of money.
N
Nikki2512
Thanks for the feedback which has been helpful and dare I say consistent. In summary appears to be not worth the extra money and potentially more trouble if not maintained correctly.
Thanks once again for everyone's input saved me time and money.
Nikki
