Mb c220 cdi hard start and poor running
Mbu53r
C220 CDi, 2002, 2.1l cdi 105kw
Hello, i am new to this club and i am looking for some expert advice.
Problem: had had of black smoke coming out even when easy on the throttle. At first thought it'd be an easy fix with some gasket changes and inlet pipe or smth. Worse things happened and turned out to be a warped head, well ****.. Had the head repaired, that took almost 2 months, put some new gaskets and parts on the engine when putting back together. Took a few days but finally got it done, ofc there was no fuel since it was sitting and all the fuel stuff was was off. Finally it cranked over but died, which is normal, but it did that wayyy too many times, and when i got it running after some time, it had no power whatsoever.
Tl;dr: had engine rebuilt, was running fine before rebuild only smoking, now runs very poorly, has no power still starts bad sometimes.
Im out of ideas of what it may be that causes this.
Also sorry if this post seems out of order, i am not a native english speaker.
Best regards,
A fellow mb owner
mrmb
Galway
W204 C200 CDI Sport Edition 125 2011 / W215 CL600 Bi-Turbo M275 2002
Injectors, fuel pump?
Mbu53r
I wanted to get them checked but haven't had the time time yet. Fuel pumps thingy that connects it to the camshaft was very worn, but will it affect the pressure? A friend of mine had STAR, it showed that it had around 350bar of fuel pressure at idle(might remember wrong). Only MAF reading was off, i dont know the normal rail pressure too.
