Mercedes specialist wanted !
fanaky
fanaky
Dudley
w209 270 cdi
  • #21
Well i need to find something cheaper . I can buy OEM intake manifold from my country with 500£ but they wont work with my parts . I need to find a place where they accept my part or give me a better price for their own .
fanaky
fanaky
Dudley
w209 270 cdi
  • #22
But even so , the air sound has nothing to do with the intake manifold , the car goes into limp mode since september and 30k miles done and the sound is new , it has several days .... they could be related but they also could not be , as long as here they cannot check this problem till the manifold its not changed i dont know what else to say
Kirbs
Sutton Coldfield
ECLASS 280 sport,2009,3.0 and SL350 2004
Good luck with that, I would not have suggested going to an Indie if I had known you wanted to take your own parts,there are any number of reasons why that wont happen .
You can phone around for a "better price" now you have a diagnosis but I would say that there will not be much in it if you get 3 quotes, and other factors such as location could wipe out the value of say 5% cheaper quote which I believe would be the best you will get
mikestrivens
Stockport
I'd be surprised if a reputable indie would accept you bringing your own parts, especially from an unknown source, as they will not guarantee the work or that it will fix the problem.
fanaky
fanaky
Dudley
w209 270 cdi
  • #25
Then i need to find one less reputable , because in the end the part is oem , same code same everything , why to pay it double if i pay working hours also
Kirbs
Sutton Coldfield
If you have said that you wanted to take your own parts[which I believe are used] then I would not have replied to you ,just advise you to find someone to fit it.In terms of less reputable I would advise you go elsewhere rather than this forum which is all about reputable and value,it appears you know more about price than value
fanaky
fanaky
Dudley
w209 270 cdi
  • #28
you cant be more wrong because my parts are new , anyway i think this discussion is going in the wrong direction only because i worked for my money like most of you guys but i dont accept throwing them on the window just because a shop or a specialist is reputable . In the end its still the same part with the same code . Ill delete this post , thanks for the advices and i wish u luck with your cars
Kirbs
Sutton Coldfield
Yes ok good luck to you as well
To help you earlier I emailed them to say that you had been on the forum and to look out for you based on your car and need
I have since been in touch to say that I didn't realise you wanted them to fit your own supplied parts.I am aware of the detail
Cheers
fanaky
fanaky
Dudley
w209 270 cdi
  • #30
Fair enough and thanks for that but still not worth it to pay 1k for something that i can buy with 500 if they asked 600-700-800 it would be ok but double is too much for me . U got me wrong , i dont want to go with my part , but in the same time i dont want to pay it double
Kirbs
Sutton Coldfield
Ok but for the benefit of someone reading this post in the future ,Its not fair to say they want double when the two things are not comparable. His part is a UK MB part with guarantees, yours is a non uk, non verified source ,I am sure its a great part but its not comparable and therefore its not double
fanaky
fanaky
Dudley
w209 270 cdi
  • #32
U are right , mine is from germany from mercedes mother land :)
Kirbs
Sutton Coldfield
Not true my friend ,like you say delete and go elsewhere
fanaky
fanaky
Dudley
w209 270 cdi
  • #34
I cant find the thread delete option .
You should search were mercedes was born and after say if its true or not
fanaky
fanaky
Dudley
w209 270 cdi
  • #35
Same forum same problem , other city other prices ....
BillyBoy
W213 E400d All Terrain
I'm quite surprised at the hostility that is being shown to Fanaky over a perfectly reasonable question. I also have found that any good indie or garage I have dealt with in the past will quite happily fit owner supplied parts, but just adjust their warranty on the work to suit. After all, we pretty much all fit non MB parts to our cars! How many forum members will only fit tyres to their car that have been supplied direct by an MB dealer? I in the past have often bought my own parts and supplied as many are pattern anyway. For example a Bilstein shock for my S Class was £200 cheaper than MB despite being the same part! For second hand parts, if they can be inspected / tested and the owner is prepared to take the risk it may not work, I don't see a problem. It is after all much better for the environment, and most crashed / written off cars still have a large number of servicable and maybe even nearly new components.
AMGeed
Poole, Dorset
S204 C180K
My indy is happy to fit parts supplied by me. In the past I have supplied discs, pads, oil and plugs and saved myself a fair bit.
I'm sure MSL would do the same if the OP contacted the owner and explained his situation. ( Acid 07765 444 447)
V6Matty
Newark, Nottinghamshire
Acid will happily do the same but he does stress they will not warrent the work so you could pay for the work to be done a d it won't fix the problem, just a risk you take.
Is your 270 a 612 or 647 engine?
BillyBoy
And of course this issue exists with all mechanics and new parts too!! How many stories have we seen in here where people take their cars in to have it diagnosed and the dealer or garage replaces a part they have diagnosed to be the problem only for the same issue to exist afterwards.
