Ml270 black smoke
Adem88
Melbourne, Australia
2003 ML 270 CDI
Hi guys I have a 2003 ml 270 cdi, it was running great until the plastic pipe from the turbo to the airfilter/maf cover split, so I replaced that along with a new maf it was good for about a week and I am noticing black smoke on accelerating it only happens when the turbo kicks in and I can hear the turbo wind up, not a whooshing sound but you can hear the boost, I have checked the hoses/pipes etc but I can't find anything, I have used only genuine parts from mercedes, thanks in advanced also it has done 250000 kms
rpe2
Silchester
E53 Estate, 124 Cabriolet, 129 SL
Was the maf a cheap ebay one our a genuine one?
oigle
2003 ML270 sold but not forgotten. 2022 Kia EV6 GT Line RWD
if you have definitely checked your hoses for splits (boost hoses), I would next suspect a jammed up EGR and coked up manifold. Common problem with these.
A
Adem88
2003 ML 270 CDI
I have cleaned the egr didn't help I didn't notice any oil on the side of engine but I did notice the manifold rod has abit of oil/gunk on it
oigle
Pretty normal for the rod to leak a bit. The filth inside the manifold has to be seen to be believed....
The egr valve can still play up after cleaning. They get marked up a bit and can stick open a bit which causes a severe reduction in oxygen values in the air volume. This in turn causes incomplete burn and black smoke.
There is a quite simple electronic bypass available that removes the egr from the system completely and prevents any issues with it. See the post by dieselman for details. I did the shunt a year ago and recommend it highly.
The inlet manifold could really do with a clean out too. It will be very restricted by the gunk buildup.
Cheers - good to see another Aussie on here!!!!
A
Adem88
2003 ML 270 CDI
Hey oigle thanks for your input I'm going to try find someone in melbourne to do the egr shunt for me as I'm no good with electronics.. With the shunt mod does the intake manifold butterfly's have to be removed or inlet manifold stays the same
stumo
VIC, Australia
ML270 | ML55 | Sprinter 316 | UNIMOG 424
It could also be your manifold flaps. Either way the EGR delete mod is well worth doing first. I've done mine almost a year ago and its been fine. You don't touch the manifold for the shunt, its just hooking up some wires.
A
Adem88
2003 ML 270 CDI
Stump thanks for your reply I see you are in vic maybe I can pay you to do the mod?
oigle
As stumo said, make sure your manifold flaps are operating correctly. If the linkage has come off or the flaps are jammed closed, you will get similar issues to yours.
stumo
VIC, Australia
Its really difficult to see the flap linkages when I tried on mine, there is a lot of junk packed under and around the manifold.
I have decided i will just remove the manifold and permanently delete them. Its a big job, I just hope i get round to it before one gets ingested and breaks the engine. Mine has similar k's to yours.
Im sure we could come to an arrangement if you want me to do the EGR shunt for you. I also have star diagnostics so can check your codes too. I'm in Mount Waverley.
mersum1es
Finland
How to I check if they are working correctly
You can see linkages below the manifold, either below front most cylinder duct or between two rear cylinder manifold ducts. When you rise revs from idle, linkages should move. But manifold can be clogged even flaps are moving. Codes will tell if flap motor is functional at all.
Like said, remove manifold, clean it, remove flaps, disable egr, and have a happy miles.
A
Adem88
2003 ML 270 CDI
Hey stumo thanks for that mate I would appreciate the shunt mod and codes read. Your not that far I'm in essendon pm me a cost and a time when your available. I appreciate it
A
Adem88
2003 ML 270 CDI
Just checked to see if the rod moves while rising the revs it, and I does freely I did notice the it dosnt stay open whilst revving higer. As soon as you let go of the throttle and blip it again it opens
oigle
That is the way it works. Looking more like an egr problem.
A
Adem88
2003 ML 270 CDI
  • #17
thanks for that i have taken the pipe of that connects to the egr and have taken a video the egr valve is opening half way not sure it is normal or not and you can also see the manifold rod working, (sorry about the no sound) . the egr was cleaned out about 150kms ago. i dont have any oil leaks aswell and my fuel consumption is so bad, (need to change thermostat aswell)
Here is the video i just made
http://www.youtube.com/watch?v=PqOemY2rZ70&feature=youtu.be
oigle
Good little vid. Certainly working. Take the opportunity offered by stumo. He can advise once the codes have been read.
A
Adem88
2003 ML 270 CDI
  • #19
Did you notice the little bit of black smoke coming from the pipe that connects to the egr
oigle
No - not clear enough. Not surprised that a bit of black smoke might come from there. if that is the big pipe from the heater/cooler matrix. Direct connection to the exhaust.
