ml270 multiple turbo failure advice req
morrow1980
doune
ml270 amg
Hi Everyone,
I bought an ml270 , the turbo failed the day after i had it,it suffered from an oil leak, i put it into a well respected inde dealer who replaced the turbo using the same unit but had it repaired, he fixed a fuel leak, done some diagnostics and charged me £945.
Drove the ml home and the turbo failed.
It was rather noisey when driving home but sounded like a loud turbo , he is taking the ml back tomorrow but i`m seriously worried about the cause of the failure.
Any ideas on what would cause it so soon?, the engine oil level has also dropped to just above minimum.
thanks in advance
whitenemesis
CLS55 AMG '05
I'm presuming it was a private sale? Otherwise it should have gone back to the dealer under warranty?
Is the "well respected" indie a Merc specialist?
M
morrow1980
doune
ml270 amg
yes a private sale, he is a specialist and does know mercs well, he was baffled as to why it has failed.
Is there a known fault that causes turbo failure so fast and uses engine oil?.
My worry is it costs more cash now.
M
morrow1980
doune
ml270 amg
mega smoke out the back, no power to drive up the hill to the house and no turbo noise at all
i havn`t looked just gave up, would a pipe loose cause all that ?
Frontstep
T210 320cdi
Sounds like its running off the engine oil when you floor it my Turbo did the same had it rebuilt and fine.
The bill seems high for a rebuilt turbo but maybe something else was done.
panason1c
Somerset, UK
Sounds like the 'repair' to the turbo possibly wasn't carried out competently, if the turbo seals fail this will cause engine oil to be consumed via the turbo at a rapid rate.
M
morrow1980
doune
ml270 amg
went out just there, there is exhaust gasses escaping from where the turbo joins the cat also that side of the turbo there is a hole maybe a bolt missing or maybe thats how its meant to be , its a mchined hole not a break but i couldnt get right in to look.
its running but a bit rough, the turbo spooled up , lots of smoke from around the area, a blocked cat maybe ? due to the previous failure ?
or if the hole is a missing bolt its been oil starvation ?
M
morrow1980
doune
ml270 amg
the only other work he done was fix fuel leak, fix oil leak it had, and get for fault codes, one of which was the maf sensor i fitted a new one and it worked fine.
it was a high repair bill given the original turbo was sent away and refurbished had it been a new unit i wouldn`t have minded.
Frontstep
T210 320cdi
Sounds like it needs to go back.
drdre78
london
mercedes c200 200
Hi if gas escaping from turbo to cat you find that cats are blocked and need replacing
M
morrow1980
doune
ml270 amg
removed 1st cat internals refitted no difference still very smoke, the knocking noise wasnt the turbo it does it when i rev it fast , the smoke is white/grey and excessive, i`m thinking injector or swirl flaps ?
V6Matty
Newark, Nottinghamshire
Starting to sound like a compression issue, white smoke is either burning oil or coolant. Where did the car come from?
panason1c
Somerset, UK
"the smoke is white/grey and excessive",
More likely to be unburnt diesel, imo. Need to read the codes on this one.
M
morrow1980
doune
ml270 amg
well today i cleaned out the egr, the intercooler ,drove it and all seemed slightly better was still rough and smokey.
then ots of smoke from engine just made it home
the first injector had been pushed straight into the bonnet, the inde told me it had been a botched job someone previous had done and it wasnt held on as it should be, so this must have been the problems with the smoke and running rough ??
needs on 1st look a rocker cover at least
