Hello, i have w212 om651 2009 sedan, but sometimes when its cold the rpm fluctuates by 50/100 up in idle other than that it runs good acceleretes good with kickdown.But after i replaced the quantity control valve on hp fuel pump Engine light has come on dash after reving it to 2k rpm and power is reduced its still fast but not as before and no kickdown.
Can the new valve be faulty cause the old one never had error codes? I never had codes before.
Should i return the old one cause the car was fast but sometimes it reved by 50 rpm when at idle?
P025285
P008800
P008700
Took it to dealer for codes here are they below.
P025285
P008800
P008700
