Panoramic sun roof
Benny Ellsmore
Registered
W205 C class 2015 c250
Hi all new here
I have a 2015 c class the sun roof motor is grinding/clicking I have had the motor off with great difficulty and when away from the sunroof it runs perfect and the gears don’t look bad I can manually open it with Allen key and when it gets past the tilt the motor pulls it back I took of the glass and I can’t see no broken bits the plastic catches I have seen people say break are both okay the only thing I noticed when glass was off is passenger side seemed a little slower than the other side and when it gets to tilt position drivers side goes down smooth and passenger side start to grind and struggle takes a few attempts also the shade doesn’t seem to move at all and no nose coming from that motor My guess is it must have a bad passenger side cable anyone know how and if possible to change a cable on them thank you
John Laidlaw
Wirral
Land Rover Discovery 4
Welcome - hopefully someone will have experience on this
SmartAmg
2011 E class coupe 350 CDI
Welcome. Benny. :)
