repairing broken W202 Key fob.
megah0
Birmingham
E300 Diesel...now with less dents!
This method works for w124 as well :)
ferretavfc
You are in deed a genius after lot's of ill gained advice about why my 1995 C220d Merc would not respond to the remote fob i stumbled on your site and your step by step guide to what could be wrong ie the inner workings of the fob becoming detached was indeed spot on, so after four small solder's it is fixed and at no expense excellent can't praise yo enough TA :
davoC220
glasgow scotland
1996 C220 diesel elegance
if only id been here a year ago, both my fobs fell to bits when i went into a services for a coffee, fortunately my mates an auto spark and mobile too, waited 2 hrs for him to come out tho, and he did the same repair in 15 mins to both fobs, cost me £50 tho, but money well spent, probably saved me near £200 replacing them
Ian Nexus
Torrance, California
W202 Estate C250TD
Hi, here is a picture of the offending article, you can see the little black component that I found loose inside. Hope this helps to clarify the problem.
This little chip is a Philips fixed code RFID tag, these are used in immobiliser systems. It does not connect to the PCB in any way, they are fitted inside many key fobs.
Best Regards Ian
Dec
Ireland.
W202
Using anywebs picture of the other side of the PCB it would seem their just isn’t any space other than in the illustration for something that size to fit, I don’t think it belongs in there at all, why it should exist is a mystery.
Any chance that the problem is simply dead batteries or incorrectly fitted batteries?
Dec
Hi Ian, that’s an interesting explanation to the above post, I was wondering how this chip turned up rederham’s key fob but not in other similar fobs, any idea what it actually dose or why it doesn’t seem to have to be connected to anything on the PCB.
We never did get any further feed back from rederham.
Dec
I managed to repair another DAS11 key today,,thats about 6 that I have fixed,,this one was a through plating hole failure
Dec
Ireland.
W202
Ian, thanks for that, would its absence from a key fob cause that key fob not to work, as in the case of my previous post?
Dec
Dec
Yes it would not work without it. they are not used in the later keys
Dec
Ireland.
W202
So I should have one in mine, I have had mine apart before but never noticed it, must check again, this is a whole new can of worms as a possible fault issue.
Dec
Dec
Dec the are many variants on these keys,,I have seen 10 different versions of the later keys,,though I have only fixed 2 of the flip out keys,,one for sure did not have that part in it
Miffy
Bromley, London
CLK 320 CAB Elegance C208
the RF chip is just the same device as put in shop security systems and door control systems, a magnetic field excites electrons in a coil and powers the chip to broadcast a string, from 16bits to god knows how many these days, we use 40bit cards for our door entry readers
Sean Ng
Princes Risborough, Bucks
1996 E230 Estate, 1996 E230 Saloon, 1995 Mitsubishi FTO Coupe
Hi Guys
It seems to me that I have the same key fob problem - broken 4-leg rectangular component.
Before I start soldering the legs, I have done a quick test but only finds that there is no red light flashed out.
The way I carry out the test is:
(1) Insert working batteries properly (fastened with tape), making sure there is contact;
(2) Hold the component back on the PCB by finger; and
(3) At the same time, press the button on the top of the component.
I wonder if I have done anything wrong in my test. Should it work by just simply soldering the legs? Hope you can help.
Regards
Sean Ng
Buttons with 4 legs have 2 straight through contacts so it must be soldered on.
The LED means nothing for the working of the key,only holding in front of a digital camera will show that it is working
Sean Ng
Hi Malcolm
Thank you for your advice. Will solder it and let you know the outcome.
Regards
Sean Ng
megah0
Birmingham
I must be super clumsy
fixed the key again today, however one of the legs on the switch has broken off now, I managed to get it working by carefully (oh so carefully) building up solder to the tiny bit of leg that remains. However if I drop it again (likely) I don't think it'll be repairable again.
Where can I get a replacement switch from? Are they common items?
Yes they are common,,,what is the size of it L x W
