Slk indicators - help please
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Hi All
Need some guidance on the wife's SLK, it's a 1998 230 Kompressor.
There is a fault with the indicators being that when indicating the lights just come om and donot flash, same thing if the hazards are turned on. This is an intermittant fault that has been going on for over a year, they can work fine for months and then stop for a few hours / days and then restart working again. I have replaced a small indicator relay (£9.50) a while ago, but to no result! If this was a Morris Minor you would just replace the good old fashioned flasher relay, but we are in 2009 and things are more complicated :mad:
All advise welcome and really need a solution - MB haven't been able to offer any real solution to the fault.
Black C55 / Television (Malcolm) are you still out there?
Cheers in advance
Malcolm
It will be the yellow flasher unit in the control unit, some details tomorrow
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Thanks Malcolm, I have looked, but couldn't see a flasher unit - please send details as soon as possible
Cheers :D
Malcolm
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Hi Malcolm - did you find any more info ??
Regards
Malcolm
This flasher is built into the combined Control module priced at , wait for it £603
The good news is that the flasher unit can be replaced, the original is a Siemens A3001-A802 V23133 Its something that I could change for you, I am just trying to locate an replacement flasher
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Thanks Malcolm, that would be great, please let me know when you can locate a flasher unit and I will "speak" to you then
Thanks for your help
Regards
Malcolm
type49
Indicators on 170s run through PSE pump in boot. Check for any signs of water leaks here first.
Interesting, thank you Type 49
Didnt know that, thought it went through the combi module only!
You learn somthing new everyday!!
If one thinks about this it is correct as the pump is all part of the alarm and the flashers will flash when locked and unlocked
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Thanks for input - I did the "mod" by turning the PSE pump upside down a few years back, so no water problems there.
Television (Malcolm) - any news on locating the flasher relay?
Thanks everyone for advise - MUST sort this intermittand fault out :mad:
I have fitted a few rotor light switches to the 170 for no indicators, the fuse holder burns out in the switch, just a thought!!
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Thanks for info - sorry to sound dim, but could you elaborate - what do you mean by rotor light switches?
Cheers
Malcolm
Your head light switch!
Fuse for the indicators is housed in the side of the unit, done maybe 5-6 in the last 2 years!!
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Cheers for that - I guess there's no way of testing the switch, although worth changing the fuse. BTW what's the cost of a switch?
Cheers
Malcolm
At the time i last fitted one they were around £55.
That was a while ago now!
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Just a thought - as my indicators come on (but do not flash) would I be correct in saying that they must be getting power, so thus would this eliminate the fuse / switch
Cheers
Malcolm
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
  • #19
television;The good news is that the flasher unit can be replaced said:
Morning Malcolm - any luck locating a flasher unit
Cheers
Malcolm
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
  • #20
Hi Malcolm - have you had any luck in locating the flasher relay
Thanks in advance
Malcolm
www.ckinsurance.co.uk
