Smell of petrol cold start W212 E250
cheapshots
London
W212 E250 (petrol) 2013
Hi all,
W212 Facelift 2.0 E250 SE, 2013, 45k
For a week I've noticed a strong smell of petrol with a cold-start (first thing in the morning). The smell is coming from the engine bay. If I'm inside the cabin with the heater fan off, I can't smell the petrol, if the heater fan is on, I can smell the petrol.
The smell disappears after about 2 mins of driving and doesn't return until the next cold start (next day in the morning).
I can't see any visible signs of a leak under the car, and even if it was a leak, surely the smell of petrol would be constant?
Any idea's?
Thank you
C
cheapshots
London
  • #2
Any ideas at all ? :)
John Laidlaw
Wirral
Land Rover Discovery 4
Exhaust manifold gasket potentially
Or exhaust leak anywhere under the bonnet.
You aren't starting it in the garage are you?
C
cheapshots
London
It’s only from a cold start. The smell comes from the engine bay.
And the car is parked on an open road.
I’m inclined to think it’s a small fuel leak somewhere and that’s why I only smell it from an overnight cold start...
John Laidlaw
Wirral
The cold start made me think exhaust manifold, when hot it may be expanding enough to push the gasket tight again
C
cheapshots
London
Ahhh i see, makes sense.
I guess I need to visit my garage :(
I’ve been kidding myself that the smell is normal!
C
cheapshots
London
Booked into my local garage on Friday, will let you know what they find. I really hope it's something minor, 6 years old car with 44k mileage grrrrrrrrrr
C
cheapshots
London
Small update:
I usually use a fuel additive (Archoil AR6200) however, with my latest fill up, I didn't use this additive and there was no petrol smell during my morning cold-start.
Hmmmmmm,.... may be a coincidence so will keep my Friday appointment with the garage for now!
John Laidlaw
Wirral
Small update:
Why are you using this additive....??
C
cheapshots
London
I got sucked into the hype around fuel additives a while ago and it has stuck ever since.
Things like this article made me initially use it
Nothing like a bit of pseudo science to help market something....
John Laidlaw
Wirral
As you probably guessed I’m somewhat dubious of the claims made, “snake oil” comes to mind, however that’s me really. If it works for you in some way why not?
C
cheapshots
London
With long term use the cars I've used it in had better MPG (1-2%) but other than that I haven't noticed much else.
John Laidlaw
Wirral
OK, I fell for it and read it!
The phrases...
“This is achieved by increasing the surface area of droplets” and “The fuel becomes more aromatic (a sign of increased chemical stability)” crack me up...more power to his elbow there. I’m guessing the author is commercially involved in Archoil ?
The phrases...
I liked the bit about lowering the flashpoint....
(flashpoint is a chemical property defined as the minimum temperature at which the vapour will support combustion - which for petrol is -45C!)
C
cheapshots
London
  • #17
Ok I'll stop using the Archoil stuff :p
The smell of petrol is much less this morning, so I will cancel tomorrow's garage app and keep an eye on it. Odd.
On a side note, do you think my cat might be a bit dirty/clogged up? If so, what are your thoughts on Cataclean ?
