SRS Airbag Sensor - Crash Data reset
Hankiss
London, UK
W221 350s s-class, W204 220 CDI AMG sport, Jeep G.Cheeroke 2.7CDI
Hello to All Members,
I spend a lot of time reading about this issue, but I’m still very confused. I wonder if anyone here has a practical experience in the matter. I recently purchased W220 320CDI (2005) which was involved in an accident. Two side and roof air bags were deployed as well as seatbelt buckle. I replaced all of them. MB Star still shows faults related to these items. Also it’s pointing to SRS Airbag Sensor (called also Airbag ECU) saying that the unit cannot be reprogrammed. Obviously the crash data is written into it and it’s blocking the unit, so Star cannot clear the faults. Merc stealer says; I must buy new unit and reprogram it (....lots of money !!!) By searching Internet I came across ads from people claiming that they can clear crash data from the unit (for £35) and make it as new. Even more, the unit will not need reprogramming. Logically, if the Bosch unit uses EEPROM or similar chips, it must be possible (using the right tools) to flash the data, modify the file (deleting crash data) and upload the file to cleared EEPROM. This is my theory.... Can anyone here verify this by his own experience? I tried to look into MB Star Developing Mode for the solution, but it is in German, so I do not want to experiment without proper guidance, as I can make more damage than good. I read some articles that some Members in the similar situation, purchased used units on E-bay and installed them to the car without nasty consequences. Again my theory is that it should work, assuming that I will get exactly the same unit with the same Bosch number and that the previous car was not involved in any accidents. That would be very difficult to get. I would be much obligated if someone here will input some solid info regarding the above. All the best, Mark
Alex Crow
Super Suffolk
Hi Mark
yes, some companies advertising SRS ecu reset services can indeed do the job - much cheaper than a new one as you said. sorry i cannot recommend one. you can also reset it back to factory (no vin or specifics coded and unlocked) with developer mode, i have done this on an earlier W220.
cleverdicky
MB
Yes it can be cleared. But you have to replace air bags first but as youve done that, that should be it. If you have any dodgy connections still (check ONLY with ignition off) it wont clear. If I remember there are a couple of levels that can be cleared. If all airbags are ok and fitted well a simple code fault reset (did mine with a sealy) will clear the srs light. But details are still stored. You need a star or a very good equivilent to clear it completely. You do not need to replace the srs unit. I did buy another replacement, I never used and still have it (if anyones interested;) but wasnt needed.
Alex Crow
Super Suffolk
i think this module has stored code B/C1000 which cannot be erased in normal STAR operations or with other scanners, but likely can be done with developer mode.
Hankiss
Hankiss
London, UK
Hi, and BIG thank you to all the Gentlemen above. I have MB Star, but don’t know German to make good use of the Developers Mode. Your info helped me to take a decision and today I have posted my Airbag Sensor to one guy from Halifax who promised to clear Crash Data for £35,-. Now I’m waiting for the unit to come back. I will post the final story in a couple of days. Thank you again, Mark
cleverdicky
MB
i dont know but wont the fault be registered in star still ?
Hankiss
Hankiss
London, UK
Hi, I'm still waiting for the Airbag Sensor to come back from reset....
Mark@RMK
Birmingham
www.replacementmercedeskeys.co.uk
115CDi Vito
In Dev mode with password..
Steuergerat enriegeln (FN_SG_Entriegeln) Unlock ECU
Crashendaten ( < Made that up as I can't remember exact german word!)
Reset/clear
Then close ecu with..
Steuergerat verriegeln (FN_SG_Verriegeln)
Hankiss
Hankiss
London, UK
Hello again. My Airbag Sensor came back from the guy clearing “Crash Data”. He said that unit is ready to be fitted back into the car. And, this is what I did. It was clear from RSR message on the dash... but not very long. Next few ignitions... and the fault came back. Went into MB Star, which pointed to the Airbag Sensor – “... wrong coding”. So, I’m back to square nr 1. MB Star want do “Initial Starup” as it say, it could be only performed on new –non locked unit. My unit is still interlocked. I will try MarkPRP suggestions in developing mode, but my worry is that S-class may have some kind of central coding (outside Airbag Sensor) which keeps RSR fault in a memory. I will keep posting...
Alex Crow
Super Suffolk
it can be done on developer on earlier w220 cars, as i said in post #2, hopefully the same on yours. dev mode - actuations - process item FN_UNLOCK_ARMIN_0_TO_1 first, then FN_UNLOCK_ARMIN_1_TO_2, then FN_WRITE_OPEN. you will then be able to enter vin and coding etc through initial startup.
is this the original module fitted to the car? if so, why are you getting incorrect coding faults?
A
andy@pcd-ltd
The only thing i can think of is they have completly wiped the control unit.
But if they have i would expect it not to be locked to the vehicle and be able to carry out initial startup.
i would contact the company back and see what they have to say about it
Hankiss
Hankiss
London, UK
Thanks Alex for your inputs. Although mine is late 2005, tomorrow I will try your suggestion in Developers Mode. Your question makes very much sense here. I asked the same question to the guy who was trying to make this work. When the unit came back from “clearance” I installed it back to the car, but had SRS fault. Star produced error in Airbag module “coding is faulty”. This is why I tried to reprogram the unit and do some coding manually. Thanks God I have the original dump file (with crash data in it). I will try to clear the crash data again and upload modified file back to the module. The coding should remain the same as it was before the accident. I will experiment some more tomorrow, and will keep you updated. Cheers, for now
cleverdicky
MB
you should have cleared the unit while it was in the car.
Are you sure there are no faults still? i.e. blown seatbelt module you might have missed ?
Hankiss
Hankiss
London, UK
Just an update on my SRS saga. I took out the Airbag Sensor again. Using the programmer, flushed the chip, modified the original file and uploaded the file back to the Airbag Sensor. Fitted back AS in the car . This time, RSR light didn’t come even without re-coding. Star diagnostic confirmed everything clear. I think, the first time, AS came back to me with wrong file loaded, hence I had RSR light on the dash and Star generated fault “coding faulty”. Now everything works OK (for time being). My case proved two things; 1.If you have a right equipment and software, Airbag Sensor can be cleared from crash data – means there is not need to spend almost £500 for a new unit. 2. If the unit comes back to the same car it was taken off, there is no need for re-coding. However, after an accident you need to replace all faulty items (airbags, buckles, belts) before clearing and installing Airbag Sensor. Otherwise your RSR light will stay on. Thank you to everybody who tried to help me here... All the best, Cheers
By the way I diod not try Alex sugestions as there was no need for that. But it is good to know this for the future.
j4gg4
United Kingdom
CLK, CLS, A-CLASS, ML
How did you flush the data and modify it?
did you get coding is faulty before hand?
I too had this problem but was told the ONLY WAY around it is to buy a new unit. Exactly like you was told.
jca2689
New Registration
South Africa
Sl500
Reset/clear
Hi there, I know this is an old thread b I can't seem to do this as it requests security access and I was wondering if you could guide me from there?
The help would greatly be appreciated.
aingaran92
w176 2013 1.6
hi guys i have the same issue here
i had a crash but non of my aibags went off but airbag light came on
i took out the Airbag module and send it of to someone to fix it but they got back to me and said they cant do it as i think they dont have the right file/ dont know how to edit the file but just tried to clear the crash.
can anyone help me with this?
module is still with the repair guy and i have asked him to send me crash file (EPROM) over to me and i will try to get someone to fix this and send it back to him but cant find anyone who can do it so i thought i ask here if anyone got some experience or can help me with this
its for a w176 aclass a180 2013
As per your other thread it needs Mercedes diagnostics to reset it
