Storage compartments back and centre and central locking not working
David Grennan
Merc Sl 350 2005
Just wondering if there’s anyone has had this problem with any SL’s ?
I can only get into my car with the key, same for unlocking the boot.
The lights flash when I depress the key for lock and unlock but nothing happens?
Saw on-line about fuses in the storage compartment in the rear behind drivers seat, but this and the cd multi changer are also both locked , along with the centre console. Won’t open and don’t want to force.
Roof is working fine.
Would really appreciate any advice anyone may have or knowledge of similar problems.
There are two Merc service dealers near me, but neither would / could look at the car till mid Sept ! As so busy .. and then will charge 135 for a 1 hr check. Seems a lot if it’s a fuse !
Thanks a lot,
Dave
2005 , Sl 350
Failed PSE pump.
Check in the boot under the roof pump. The PSE pump sits in a foam enclosure which often gets soaked if there is any water leaking into boot.
You can disconnect the air lines to the pump and blow/suck on them to release locks.
D
David Grennan
Merc Sl 350 2005
Failed PSE pump.
Thanks for that, did a bit more google and saw the pump could be the problem, was hoping wasn’t as only new one 4 years ago, when it went then locking problem was gradual over a few weeks, car doors wouldn’t open and this time instantly, just stopped.
Think I was hoping wasn’t the pump and a fuse.
So if I do that as you said, will unlock the storage compartments, but do you think probably still a new pump needed ?
Have seen a lot of dam in the boot at times.
Thanks,
Dave
Yes +1 as above, the boot should be 100% dry, if not the pse pump will fail in short order!
D
David Grennan
Merc Sl 350 2005
Thanks, appreciate that, looking like the pump so, not a cheep replacement unfortunately.
Do you know are they possible to fix?
They can be fixed but it's dependent on the damage.
If it's just the motor then they can be replaced. If the PCB is water damaged, it's not likely to be repairable.
D
David Grennan
Merc Sl 350 2005
Ok thanks, suppose I’ll just leave into Merc garage and see what they say so or / and look out for a replacement on line.
Cheers,
Cheers,
Depending where you are we may be able to suggest a good independent (such as Alex above). Labour costs will be far cheaper than a dealer and our recommended indys are often better at resolving issues than the dealers.
John Laidlaw
Wirral
Land Rover Discovery 4
^this David, especially on ‘older’ models as main dealers are frankly only interested in up to 6 year old service plan related cars generally, so train on those and lose interest and skills in the good stuff!
Bread and butter for the indies though
D
David Grennan
Merc Sl 350 2005
Thanks for all the reply’s.
That all makes sense and better with local mechanic. Have a great guy who looks after most times for service etc. But away for weeks.
My priority at the moment is getting the centre console etc open, so will try that blowing on airlines into pump see if locks open.
Will have a look online for a bit of help on that one.
Any other ways to open locks inside ?Is there any kind of master unlock switch or anything similar?
Had to force open the petrol cap today as also locked.
Don’t want to do that with others!
Will then start looking on line for a 2nd hand pump.
Best,
Dave
drmw
Yorkshire
www.autonomed.co.uk
You haven't actually said if you have checked the fuse - if it's blown it will be sign of something else, but at least it gets you going. Pull the drivers seat forward - there is a "leather" covered area behind it. Put in a big screwdriver at the top & it pulls out (it is there for this very reason). Look in - there will be a yellow fuse about mid way - using a pair of needle point pliers you can pull it out.
caitscar
New Registration
SL500/2005/V8
Did Dave ever solve the locked compartment issue? I'm having the same problem.
