The saga is almost over - 2005, C220 CDI Classic SE, S203.208 (Estate), OM646.963 Engine
umblecumbuz
Wales and Gozo
Thoroughly clean every face (w+d will do this), service the calipers, then reassemble.
Good to go!
umblecumbuz
Wales and Gozo
Really, you've ended up with two threads on the same topic.
Some posters on one thread, others on t'other.
Getting confusing now, so will take a back seat and just spectate.
NBurns
NBurns
Sunny Hampshire by the sea
www.facebook.com
A180 CDI AVANTGARDE SE CVT,169.007, 2009
  • #264
Eh?!! How have I done that?!!
NBurns
NBurns
www.facebook.com
  • #266
Have been forced to stay dry today what with the storm. Managed to get my forms done for the Armed Forces Compensation Scheme. Which one of my former colleagues has told me i am entitled to. A 22 page form though.
And i need to contact Co-op re the fuel contamination issue.
joderest
ML270 2003
erm, what other thread is that ?
I think you deserve this car to be correct
NBurns
NBurns
www.facebook.com
  • #270
There is between 0.5-1.00mm movement of the wheel bearing in the wheel hub. I will gauge the OSF wheel shortly.
Okay the OSF Wheel has between 0.75-1.2mm movement.
NBurns
NBurns
www.facebook.com
  • #272
This is how I adjusted mine.
Good video. Have watched that recently. I prefer the way he does the NSF Wheel as opposed to the OSF Wheel. He skips stuff for the second wheel.
But still very good.
Thank you
NBurns
NBurns
www.facebook.com
  • #273
Okay. I strongly reckon that my brake calliper pistons have indeed seized up. And therefore need removing cleaning, lubricating and replacing again.
. Interesting but not my system.
Your system is single piston, so all you need to do is pump out one piston
NBurns
NBurns
www.facebook.com
  • #278
Okay. Another question for you all. And I've already written this 3 times already to get the right answer for my question!!! Doh!!
Okay, what is the most effective way to clean the front brake discs, the callipers, the bracket, the piston, the pins, and even the bolts? Which will then need re-lubricating with both Red Rubber Grease for the piston and I believe either a blue or green grease for the pins? Even if it is good old fashioned hot soapy water and elbow grease and then dried meticulously before re-installing onto the front axles. And what basic cleaning tools should one use?
