Oldspanners
- Oct 30, 2017
- Location
- Normandy
- C CLASS 2004 C180
Unfortunately it doesn't give the thickness of the flange which would change where it sits on the hub but if the material is the same thickness then you're correct.If I read these two drawings correctly... (using the 300 mm diameter discs) the disc would end up sitting 3mm closer to the inner side of the caliper carrier.... but its sitting against the outer edge... so can't be this idea?
