The saga is almost over - 2005, C220 CDI Classic SE, S203.208 (Estate), OM646.963 Engine
Oldspanners
Normandy
C CLASS 2004 C180
If I read these two drawings correctly... (using the 300 mm diameter discs) the disc would end up sitting 3mm closer to the inner side of the caliper carrier.... but its sitting against the outer edge... so can't be this idea?
Unfortunately it doesn't give the thickness of the flange which would change where it sits on the hub but if the material is the same thickness then you're correct.
RhodieBill
Central South Coast. (Previously Out of Africa).
2001 W208 CLK320 182U ALMANDINE-BLACK METALLIC
The two drawings above indicate the other way around.
Measuring from the rear face of the disc, the height (offset) is the same in both cases, but the 300mm disc is 3mm thicker towards the outer face.
Secretly, I think the OP is rebuilding the entire car and is using this forum as a knowledge base to save buying a Haynes manual. This thread will run for years until the last bolt has been discussed, then he will publish the redacted results and start another thread on his next car!
If we all live that long...!!! :eek:
Jim2
Maybe so, but I'm sure that people are learning from it too. I am anyway, and at this stage, it's like watching a series on NetFlix,,,,,and you can't wait to see the end, and how it will turn out !!!:D:D:D
d215yq
Valencia, Spain
1987 W124 300D 280k miles
Checked this and yes the disc bolt hole does line up. Just have an old sheared off bolt stuck in the hole where that counter sunk bolt should go.
Could it be that the remnants of this bolt are preventing the disc from mating properly to the hub?
Jim2
If it was protruding a bit, and not lined up with it's corresponding hole, it could indeed be throwing of the the disc alignment.
Taffy7hfa
Oxford
Hi NBurns, Just spent a happy hour reading this fascinating thread :coffee:, Any chance of some photos of the car in its entirety ? :)
NBurns
NBurns
Sunny Hampshire by the sea
www.facebook.com
A180 CDI AVANTGARDE SE CVT,169.007, 2009
  • #229
Umblecumbuz, you know me too well already!!!! How did you figure out my overall plan?!!!!
NBurns
NBurns
www.facebook.com
  • #230
Credits will be given at the final episode!!!!!
NBurns
NBurns
www.facebook.com
  • #231
Yes, you are correct. Only by about 3mm before as I have been attempting to get the damn thing out using every single method I can think of. It is now about 2mm but I can measure that.
NBurns
NBurns
www.facebook.com
  • #232
Yes, yes. You're absolutely right. Even if that was just 3mm, that would clearly put a slight offset onto the wheel which would in turn cause an offset between the pads.
My plan of action. First, get that sheared bolt out. Secondly, check the NSF wheel just in case the same has happened. Second, now that I have removed the pins, clean and re-grease them thoroughly. Thirdly, if it is possible, remove the brake calliper piston, clean thoroughly, re-grease and replace. Repeat on NSF if required for everything. Then replace all brake fixtures, re-fill reservoir with new brake fluid (as I've lost some already), bleed the system of air and then onto the suspension arm on the OSF. Damn!!! Forgot about that. Already found a reasonable priced one online, just need to get it and fit it.
What is a failure on the lower rear wishbone arm anyway? He showed me where it was but not what the failure was.
d215yq
Valencia, Spain
I'm not sure I fully understand...
Is the sheared bolt stopping the dsic coming off, as in it's sheared with the disc already attached? And if so how is it also stopping the disc from mating with the surface? It was my understanding that the sheared bolt was not holding the disc on so was not really a problem as that bolt isn't needed anyway? But then I thought it was the caliper bracket that was stopping the disc being removed and my understanding is that has since been removed so the dsic should now come away...?
Besides if it is really 3mm then that could be your problem. It may not be enough to centre it but it maybe enough to make it stop catching?
joderest
ML270 2003
Had this on a Mini, screw sheared off in the hub.
Drilled it out with a drill just under the screw size and then picked out what was left, then run the correct tap through to clean up thread.
You can get away with out them, but the point that the remains of the screw could be holding the disc off the hub is a valid one, as the disc will fit in five different positions with out using the screws, If you cannot get them out, either file or grind them flat. The wheel bolts will hold the disc on, but be careful not to get anything behind it when fitting.
Its always best to use the retaining screw though.
One day we will have a resolve to this issue.
umblecumbuz
Wales and Gozo
So - what is the diameter of the disc, now you have removed it?
NBurns
NBurns
www.facebook.com
  • #239
Sorry. I have now been able to remove the disc. And in doing so found the sheared off bolt.
NBurns
NBurns
www.facebook.com
  • #240
Apologies for the very rough measurements. If my vernier calliper set suddenly turned up I could measure this more accurately. IMG_8089.jpg IMG_8087.jpg IMG_8086.jpg IMG_8085.jpg IMG_8083.jpg IMG_8082.jpg IMG_8080.jpg IMG_8077.jpg IMG_8076.jpg
