NBurns
- Jun 16, 2019
- Location
- Sunny Hampshire by the sea
- Website
- www.facebook.com
- A180 CDI AVANTGARDE SE CVT,169.007, 2009
- Thread Starter
- Thread starter
- #181
I'm still not sure why you can't just reassemble it all again and then spin the wheels after a test drive. The disc may not be in the middle of the holder and it may not be perfect but I understand you are tight for time and money so if it all works when you put it together it will be fine for the MOT and may well, if the car gets proper use, work fine until the pads wear out completely.
It looks like the wheel bearing hasn't been fitted correctly into the hub and is sitting out too far.
This may have something to do with the wheel bearing being loose at the MOT.
Does the disc turn with out touching the bracket ?
If it does you could risk an MOT, and then sort out after, if it does not you will have to fix before hand.
All i can suggest is something like a 24 volt impact gun to get the bolts out, as you will have to to either sort out the issue or change the disc's.
ah I see it was mentioned before....
if the disc is fully seated on the hub clearance should be equal
Already got the compressor air gun onto it won't budge. Next is a breaker bar.
There are many types of compressor air guns - some are very low torque guns, not at all like the type that garages and tyre fitters use. The usual 'Ebay' domestic guns are very low powered,and would have difficulty removing the proverbial skin ....
I still do not understand why this, let's be honest, "shed" wasn't scrapped months ago! Just throwing good money after bad..... Crazy!
Not really. It has simple to fix faults but the OP is cash strapped which makes it difficult. At the same time he's having to learn how to do things which under normal circumstances he may have just told the garage to do (as many on here would).I still do not understand why this, let's be honest, "shed" wasn't scrapped months ago! Just throwing good money after bad..... Crazy!
Frankly I admire his persistence and desire to learn and once this is complete he will surely exit this episode with a much better understanding of how to do things himself properly.
Is it fully seated on the hub? If you rotate the disc is it catching equally all the way round? If you put in a wheel bolt opposite the countersunk screw does it improve things?
