All in the hands (or feet) of the drivers. I regularly get 70 to 80 kilometres from a set of tyres, admittedly on lowish powered vehicles like ML270 and a Nissan Maxima 250. I just don't abuse tyres. My new Kia EV6 might present a different challenge with it's instant torque. Have to wait and see there.What ever happened with tyres 20 Yr ago 40k km was not out of question.
My 911 can on full lock as well, guess it's part of the geometry - it has had full alignment and most of the suspension and control arms replaced to keep it correct in my ownership. Only notice it maneuvering around and usually in cold weather.My 55 skips on full lock, forwards and reverse. Has had the best tyres and the worse tyres fitted during my ownership. It makes no difference. Even the Hunter 4 wheel computer alignment that was done. I'm used to it now, but it doesn't do it all the time
Ever tried winters or all season?My 55 skips on full lock, forwards and reverse. Has had the best tyres and the worse tyres fitted during my ownership. It makes no difference. Even the Hunter 4 wheel computer alignment that was done. I'm used to it now, but it doesn't do it all the time
Aye, I agree on that score, when I bought my W205 back in 2017 from new it was shod with P Zeros (Made in China by the way) and started crabbing.Just reading the first para I was going to say Pirelli P zero tyres are pants, a very hard tryre and suggest getting them changed.
Under 12 degrees my GLC crabs with Goodyear eagle F1 XL fitted . Learning to not overturn the steering wheel.The crapping / skipping on the Cayenne with front Pirelli P Zero 285/30/22`s is horrendous , if temps are around 0 degrees. So much so i have been looking at getting a set of 20`s for the winter months.
The previous model had air suspension and 21`s and although evident it was no where near as bad as it is on the newer model.
Contemplating fitting a set of H+R lowering springs (-35mm) but i dont know if it would make the issue worse ?
K
Recall that a friend who was a company rep drove a Vauxhall Cavalier MK2 that had almost 80,000 mainly Motorway miles on it and was still on the factory fitted tyres. At first I did not believe him then we had a local chap come in for a replacement tyre on his MK1 Cavalier as he had damaged it and wanted the same type only to find that it was not available being a special tyre made for Vauxhall for new cars only. This chap bought his Cavalier from a car hire firm at Gatwick Airport him living in the next door town (Horley) so they can make tyres to last however where is the profit in that when they can make tyres that wear out in 5000-15000 miles which people accept.What ever happened with tyres 20 Yr ago 40k km was not out of question.
A lot of summer tyres lose flexibility and grip once temperatures drop below 7 Centigrade, its one reason to fit winter tyres as they are made from a compound that stays flexible and therefore has better grip at low temperatures. Its a common misconception that they're only for snow.The crapping / skipping on the Cayenne with front Pirelli P Zero 285/30/22`s is horrendous , if temps are around 0 degrees. So much so i have been looking at getting a set of 20`s for the winter months.
K
Hmmmm, my P Zeros were crabbing in the height of summer.A lot of summer tyres lose flexibility and grip once temperatures drop below 7 Centigrade, its one reason to fit winter tyres as they are made from a compound that stays flexible and therefore has better grip at low temperatures. Its a common misconception that they're only for snow.
I'd highly recommend fitting winter tyres for the winter months. If you have the space and money a second set of rims and tyres is the way to go, you'll need to store the unmounted set away from direct sunlight either hung by the rim centres or stored flat to ensure that the tyres don't develop flat spots.
The bonus is that you can go for a higher profile tyre which will save you money both in purchase and from pothole damage.
Must of been a miserable 4 weeksHmmmm, my P Zeros were crabbing in the height of summer.
All seasons is what I usually buy.
I have never bought, tried or driven a car with winter tyres in my entire life
And on small round stones left on a the road after the road sweeper has been down
Crabbing - it does make me think that manufacturers should have acknowledged the problem as a characteristic instead of pretending it doesn’t exist. My rear wheel drive BMW does it just the once when leaving the drive due to the mixed road/path cambers involved. The E53 does the same but crabs several times relative to how low the temperature is.
Much better to give an explanation in the owners manual education is much better than denial I wonder how many cars have been rejected due to this my wife was quite alarmed when she first heard it one frosty morning just after we bought the car and wanted to reject the car until I explained what it was. The current trend of ultra low profile tyres don’t help there is little to no flex in the sidewalls and tread
Michelin Cross Climates cured mine and they seem to be wearing very well after 7,000 miles
