Viano Electric Doors & Alarm
N70ALX
Registered
Viano 3.5 V6 2008
Hi there,
New to the forum, and looking for a bit of advice on electric Vito/Viano doors if anyone experienced similar? I've searched around but not found an obvious solution.
Our Viano goes through stages where the alarm goes off every few days, totally unprovoked. We seem to have narrowed it down to faulty electric doors at the back. We also often find the battery dead.
We took it to an auto electrician who tested it for battery drain, and said it was miniscule and would take weeks to go flat. They didn't notice the alarm going off, but fixed the back door which didn't open from the inside. They said they cleaned up the contact plates, and that the only further thing we could do would be to replace the contact plates, and to bring it back if it was problematic.
For the next two weeks it went off all the time, so we replaced the spring contacts on both doors, and the flat contacts on the back RHS door. It was fine for quite a while, but it's started happening again. Today I jumped in to see which door was open, and it said back RHS. so replacing both contact plates doesn't seem to have fixed it!
We think, if we aren't here when the alarm goes off, the back lights stay on, and drain the battery. Not sure where to go from here, disconnecting the alarm siren won't stop the battery draining. Has anyone experienced anything similar, and found a solution?
Thanks in advance!
M80
Derbyshire
Most likely the locking mechanism.
A small micro switch within can become faulty, I looked for a replacement like for like switch but didn't find one.
fritoes
New Registration
viano 3.0 v6 2009
Hi there,
Thanks in advance!
good day,
my car seems to have the exact same problems, did you figure out a solution to the battery drain and alrm siren
good day,
Hello and welcome,
Yours could be the battery corroded in the alarm siren, quite a common issue, covered many times on the forum.
M80
Derbyshire
