W123 280TE Tyres
London
1985 Mercedes 280 TE
I have bought a set of Mexican Hat alloys that have come off another W123 TE. Could anyone recommend which tyres would be best to put on my 280TE and if appropriate a reasonable mid range tyre? I currently have 195/70/R14 91H tyres on the car. Thanks.
London
  • #2
W123 Tyres HELP
Hi - anyone any idea which tyres to fit to my new Mexican Hat alloys for my 1985 280TE? Any advice would be appreciated, tahnks.
Onne
Ripley, Derbyshire
1990 W126 300SE
If these new alloys are a different size you can use a tyre calculator (Google it).
This allows you to see what difference in speed a different tyre would give.
Hope this helps...
jberks
Lots of good mid range tyres on the market. I suspect the Mexican hat alloys will be 15" so you'll probably need to go to 195/65/15 but it's hard to say without knowing the size of the alloys. In those days the width didn't vary much and we had a 280E with those alloys and 195 tyres. It might be wise to double check the wheel size though. It should be printed on it.
London
Mexican Hats
Thanks. Iit seems the Mexican Hats are also 14". Would anyone recommend changing the tyre size from my old steel wheels to the new alloys or should I stick to the 195/70r/14H as originally speced for the car as I need new tyres anyway?
jberks
Always keep to the original sizes. The car was designed to run on them. The 280E was never a sports car anyway - just a good cruiser. If you changed them you'd not get better handling but you would need to tell your insurer.
