PiltdownMan
- Jun 17, 2009
- Location
- Darkest Yorkshire
- 1992 Mercedes 300TE
Hello! First problem I've had with my 300TE: the ABS does not function, and the ABS light does not come on at any point (not when you turn on the ignition, or when driving).
Otherwise the car drives with no problems.
I have read some threads about the OVP relay failing, or the fuse failing, causing the ABS to go off, but they all mention the ABS light as being illuminated on the dash. Mine isn't, so could it be something else? The car doesn't get much use and has had a new battery in the past few weeks.
Any ideas greatly appreciated!
Ted.
Ted.
