JensH
Mornin' all,
Not posted for a while, because I have been enjoying several 1,000s miles of trouble-free, if high fuel consumption, motoring (well allowing for indicators packing up (fuse) and mystery flashing recirculation button, on Diavia A/C system).
Now, though, I appear to be having rear suspension issues - a bugbear of many a T-model owner!
Over the last month my ride has become very bouncy at the rear. This followed a month of driving in Europe on higher tyre pressure, and possibly, borderline loading on outward/return trips - I suspect this means the shear pin may have gone in the hydraulic pump? There were no symptoms, before this trip - 3,000 miles in about 6 weeks. During this trip I also had seven aboard on several occasions.
Generally the handling is fine, except after a bump, when the car frequently (not always) sets into a wobbly (and car sickness-inducing) bouncing. This always settles down, but in London, with all its traffic calming, it is a nuisance. In-car conversation during the bouncing assumes a slight vibrato...
On my last (144k 'B') service a couple of weeks back, Autodeutsche (Camden) confirmed my own thoughts, which is that it was the gas spheres on the rear axle. Car had lost hydraulic fluid. They also suggested that I should replace struts and springs at the same time as doing the spheres - £800 before parts, which I would source myself, so an expensive fix. The also made muttering noises about complications from corroded bolts (meaning the "fix" may damage the hard pipe lines).
Yesterday I ran diagnostics with my little flashing gizmo. This threw up only two codes: for the left and right rear axle solenoid valves. All else clear.
I have no issues with power steering or other hydraulic functions.
My questions:
1) If the pin is sheared, is there a simple fix or is it always a new pump?
2) How can I test for a failed shearpin?
3) If I do the recommended rear axle work, should this be with genuine MB parts or are there aftermarket options, or could I use s/hand recons? - I have several reliable sources for parts of each type...
4) Anyone any other ideas?
Cheers all,
Jens
My questions:
Cheers all,
Jens
