Bunriots
- Dec 24, 2022
- W126 420SEL 1991
Hello all,
This is my first post on this great forum. I have a 420 SEL 1991 which we are in the process of recommissioning. It was laid up for over 10 years in a barn. It runs very lumpily, misfiring slightly, and very frequently cuts out at low revs. It starts first time every time, even after cutting out but after some time running it starts to cut out, dying slowly and not responding to the accelerator. It will then start first time and accelerate fine until the next time it gets to low revs. In heavy traffic where speeds are 20-30 MPH it will also try to cut out, which I counteract by slipping it into neutral, revving it a bit, and then putting it back in Drive at the slightly higher revs (with the resultant jerk as it reengages Drive). I'm sure this is not good for the gearbox. We have changed all the fuel pipes and one of the pumps around the fuel tank and the fuel filter as we thought this might be the issue, but this made no difference whatsoever. We have also changed all the plugs and HT leads - two of the plugs were a bit oily, and a third one had a white tip, possibly indicating a lean mixture. We changed the distributor cap (as it was cracked) and the rotor arm. We are at a loss now. What could it be? Is it still a fuel issue? Is it a timing issue? Is it the injectors? Is it a controller? Any suggestions would be very welcome.
Thanks!
Dermot
Thanks!
Dermot
