W204 indicator problem..intermittent!! Help!
Ap69
Lancashire
W204 2008
My c class w204 57 plate has a weird problem! When you start the car indicators work fine, after a short while they will suddenly stop so cant indicate left or right! Once i switch the car off and on they will be back on but only for a short while! Anybody else come across this issue?? Sometimes i have to switch it on and off a few times before they work again!
Any help appreciated!!
Never heard of this one and it has not been up here before,, i would think thje car needs to go on STAR to see if the fault is recorded, it could be a SAM problem
A
Ap69
Lancashire
W204 2008
Thanks for you reply..is the sam specific to indicators? Hazard light seems to work when the indicator stops!! Headlights wipers/washer all work too...its only intermittent..just came back after driving for 30mins no issues..
A SAM is the electronic storage device that has these things built and configured in
markg14
Essex
C-Class Sport C220 CDI 2007
I had a problem where the indicators stopped working - took it into MB and they diagnosed a software problem.
New software uploaded and no problem since.
Thanks for your reply,,, and yes it could just be a software problem in the SAM and it probably is :D
A
Ap69
Lancashire
W204 2008
thanks, was it the rear SAM software update? or a general software update?
A
Ap69
Lancashire
W204 2008
Just an update, STAR came up with hazard and indicator fault! Not a lot of info..now do i change the stalk as advised by the garage or do a software update? Need to know if i need a sam update or general update?
I would settle for the update for the other things could be false readings
