So, W210. Petrol 2.8 6 in-line (M104.942) became difficult to start the other day, normally not a problem starting. Ignition on (normal), crank (normal), engine fires very briefly and abruptly stops. Continued attempts initially achieved a slightly longer engine run (maybe 1/2 sec) and again sudden stop. Further attempts achieved, say, 1 sec engine run and then sudden stop leading to 'battery not charging' fault warning. Continuing same procedure extended the run time slightly with same result until after about 10 tries it eventually ran (normally). Reversed out and drove a few yards when had to stop to wait for another vehicle to move, at which point engine suddenly stopped again with 'battery not charging' fault warning. Again a job to re-start much as before with same repeating fault warning (which comes on after the engine stops, not before). Eventually ran (apparently normally) after a few more goes at which point I decided to just drive 100yds and park it up, but left it running (idling) for about 10 mins when all seemed normal before switching it off. (Have yet to try starting it since.)
Before this I'd noted it on the last few occasions of somewhat infrequent use it wasn't quite as 'clean' starting as normal - not always going on the first turn of the key, instead initially firing briefly but stopping. But once it went 2nd or 3rd crank it was apparently fine. (Battery is good and charged, no other known issues.)
On two previous occasions (one about a year ago, one maybe 3 or more years ago) the engine has also suddenly stopped when the car was stationary waiting for a pump to come free at a petrol station. The 'battery not charging' fault warning displayed. Left a few moments it re-started without problem. It has never stopped irregularly otherwise over the 16 years I've had it, to the best of my recollection. It's has no known unresolved faults, has not had any recent electrical attention other than a plug change last year and normally runs a treat. (It has not had a diagnostics check.)
The engine stop is abrupt and instant. No misfires or stuttering. Just 'on' in the one moment and 'off' in the next. (The 'battery not charging' alarm extinguishes on ignition key 'on-off-on' reset.)
Could the fuel injection suddenly cut fuel to cause such behaviour?
This car has a 3rd party immobiliser fitted. I don't know the branding. It has 3 relays, one cuts the ignition, another the starter and, I presume, the third somehow cuts the fuel (but I have not traced this, the wire goes elsewhere to the other two). Would there be an additional fuel shut-off solenoid fitted somewhere, and if so, where might this be located? Or would could it be somehow used to turn off the fuel another way - e.g. does the vehicle have some other (MB) fuel shut-off valve?
What other features of the vehicle might also cause this issue?
