W210 Decat with straightpipe inside experiment
Smaltze
london
E320 S210 2002
W/S210 E320 2002
I deleted my primary cat a week or two ago inspired by Alexanderfoti's guide, i could definitely feel the effects. Unfortunately i could also feel the negative effects in that i had a noticeable reduction in low end torque and throttle response. It was barely any but enough to bug me.
I do enjoy trying to find solutions to problems, so i set to work :)
I knew that the reduction in torque etc was because i had left myself with a massive chamber right behind the turbo, which meant horrible exhaust airflow velocity. It just meant my power band had been raised in the revs to where the pipe size wasn't such a factor..
Anyway i wasn't such a fan of this since i think lower end torque is definitely more fun since G's off the line is where i get most of my kicks!
The aim - Mod the cat somehow to increase the flow velocity.
Solution - Stick a straight pipe in there that directed the air! (as much as i could)
I intend to go all in, cut open the cat and weld/shape things into a secure sealed pipe or something in future but for now this was just an experiment.
(I figured id need to keep the cat body intact for MOT, please someone tell me i can loose it though ha :))
Heres what i did.
The Cat exit hole to the chamber is a very akwardly positioned at about 70 degrees and too the side. I was thinking of making a tube with a bend but i wouldnt be able fit it through the top whole of the cat. I just wanted something to test. Heres the design i used:
Making up the correct size pipe (ended up being about 65mm diameter)
Complete tube
Cutting a cylidrical shape out of the edge on the exit end. (refer to next picture)
This is roughly how the end pipe was positioned, except it fitted much much better for real.
Thats the profile of the Cat, and the dotted line is the pipe position.
A better depiction of the shape pipe i used. (forgot to take a picture:confused:)
This is the tube almost in place in the cat, it ended up fitting extremely well, it was almost sealed against the back wall of the cat, the slanted rear wall of the cat pushed the pipe downwards closer to the exit tube. the cylinder cutout actually ended up nicely above the exit tube there was frankly minimal excess space for the air to escape in other directions.
The tube wedged in perfectly into the cat and actually sealed itself all along (loosly), when it was in its final place the edges of the pipe didn't overlap like in the picture and it was plentifully air tight. I opted not to tack weld the tube closed so that is had some flexibility (weird idea i know but it worked).
Now lets remember this was a test, i was simply going for as directional and air tight of a tube as i could get without butchering the cat and welding things. I planned to do it properly if it had worked...
And it DID! A test drive quickly concluded that it worked, and worked well!
The car resumed alot of its low end torque, perhaps not as much as i had hoped, but it also certainly felt faster in general. perhaps i had found a better middle ground, a good combination of strong air flow!
I now plan to redo this, ill cut open the cat so i can make a proper shaped pipe and seal it all for maximum air flow.
A big question i must ask though, does anyone know if i even need my primary cat in place to pass MOT? i have my two secondary cats untouched. It would be ideal if so because i could weld the two end fittings onto a straight pipe instead of worrying about the stupid cat chamber looking intact for MOT!
I know some people may not approve of my cowboyish modding antics, but i just thought i would share anyway! im having fun and learning alot :)
Cheers!
I for one do admire the work that you are doing :D:D As all cars will pass the test on the little upper CATs, I can see no reason why they should not pass on the lower ones, they are after all much larger. What do you do with the after CAE sensor??-
Smaltze
Smaltze
london
E320 S210 2002
The upper cat in this instance is actually massive, maybe my maths is wrong but by looks is actually bigger than two lower cats combined. its about a 7" tube chamber! I just wondering if i completely remove it though and still pass MOT since i still have atleast the lower cats intact.
Not sure which sensor you mean by the way, Oxygen sensor?
No o2 sensors on these Malc. Looks good!
Smaltze
Smaltze
london
E320 S210 2002
Alex now that you are here, you don't happen to have an ECU remap file from when you had a e320?
Also maybe you would know whether i actually need the Upper cat for mot?
I am always here :)
I think I do, I will need to have a look around. It was quite a strong map, so your engine needs to be in top top shape re injectors and fuel pump, or they will fail quickly.
The rules changed a couple of years ago, and technically they can fail you for having a straight pipe in place of the cats, however, I have never had a car fail with only one set of cats.
Smaltze
Smaltze
london
E320 S210 2002
I am always here :)
If you did have the old remap file id be giddy! ofcourse id take caution using it though. will make sure everything is ready.
I think i will also enquire with my prefered mot station, my next one is in november as far as i remember!
You must also have the car connected to a 12v power source when writing, as it spins the AC fans at full blast which can cause an incorrect ECU flash, which = bricked ecu
Smaltze
Smaltze
london
E320 S210 2002
yeh, i had seen that mentioned elsewhere and can do that no problem, duely noted!
No worries, better safe etc.
Naraic
2005 CL500.
Is this a petrol or diesel?
V6Matty
Newark, Nottinghamshire
I've removed both the cats on my 211 270 and it's been through an mot since by someone that didn't know the cats were removed and it flew through the emissions test and the mot without a problem
Had yours been replaced with straight pipes or been bashed through?
V6Matty
Front cat was done with strait pipe and the rear just banged out so looks stock to the tester. Saying that he has tested my families cars for at least 20 years so would tell me if he wasn't happy with anything I'd done.
Should say it was all done by Imran at Tourqueflow, and he even advised if I had a problem at mot time he's put a new front cat in for me at no cost he was that confident
front cat, you would probably get away with as its near impossible to see anyhow. lower (second) cat is much more obvious.
personally, i gutted both cats on my C220CDi and it was the best mod i ever did! boost came on at around 1500rpm (it had been slightly less but only 100rpm or so) but it was no issue as i found with the 220, much under 1500rpm and it laboured a bit more than i like anyhow, so i tended to stay over 1500 anyhow, 1300 being kind of a minimum, especially above 2nd gear.
i noticed no real change in exhaust note, although the turbo was slightly more audible (that whistle you get) which i really didnt mind at all. it was probably the best change i made to that car, mechanically
V6Matty
I find very similar to you Pete, boost comes on slightly later but more like 1300 compared to about 1200 it was before and yes the whistle is more noticeable but I like it, I do notice chatter more from the waste gate but I like that too so all good in my book. Oh the BCM filter may have helped too
Smaltze
Smaltze
london
E320 S210 2002
  • #19
Contemplating clearing my secondary cats.
Putting in a straight pipe in place of my backbox at the end of the week when pipes arrive. only reason i havnt cleared the second cats is because i dont want my exhaust TOO loud. Alex you would know about this right since you cleared your secondary cats eventually? is the sound difference a thing?
I think i probably should just straight pipe my upper cat, and at mot time if it does fail ill cop a ****ty old cat from scrapyard or something and get it on. Definitely would improve even more on the airflow goal i had with the build in this thread.
the 220 i had there was little or no volume difference to the exhaust, but gas flow at higher RPMs made quite a difference, or at least felt like it did. it revved more freely.
you may find the need to fit a silencer of some sort, even if a smaller/custom one at the rear, as if its the same basic exhaust set up on the 320 as the 220, then the ONLY silencer in the system is the rear silencer!
personally, id be tempted to gut the cats and leave the silencer in place. gutting the second cat would probably give you more benefits from an airflow point of view
