W211 E270 power steering fluid - where and which type?
motocod
Devon
W211 E270 2005, ex W124 300CE 1989
Hi Folks,
I'm getting a bit of groaning on my power steering on my 2005 E270. Can anyone please advise where the fluid reservoir is located? It would appear as though it might be hidden under the plastic engine cover - with dark evenings and always at work I haven't had the opportunity to look yet. I appreciate the groaning may indicate fluid loss, so that will be investigated in due course...
Also, what kind of fluid do I need? Can I just grab something in Halfords?
Thanks in advance!
Nik
DREAMER NO2
W124 2.6E M103 1989
Mercedes only , dont use any other pas fluid . For a short time get you by you could use a universal fluid from Halfrauds and then later on flush it all out , and replace it with Mercedes PAS fluid
motocod
motocod
Devon
Thank you - appreciate you taking the time to reply.
motocod
motocod
Devon
Would you be able to advise a specific grade I need to look for, please? This kind of information doesn't seem to come easily on the internet (although I'll look in the owners manual when I get home later).
Thanks again,
Nik
mioba
Nottingham and Köln
OP,
Dont bother with Halfords. You need the spec. Take a trip to yout local MB dealer.
PS fluid doesn't disappear so look for leaks.
Id be inclined to replace all the fluid, easy to flush.
motocod
motocod
Devon
Thanks very much, appreciate your replies!
onefortheroad
uk.
It's more commonly known as CHF nowadays. If it's green . Which I think yours will be. If it's red it'll be automatic transmission fluid . Screenshot_20240116-202029.png
motocod
motocod
Devon
Thank you, that’s really helpful. I’ll hopefully get to check it on Friday.
Assuming it’s CHF can I simply top up with the Halfords stuff, or does it have to be MB?
AndySlade
Tadley, Hampshire
C220 Diesel Estate, Sports Edition
Use the attached link for M-B Fluid Specs
motocod
motocod
Devon
Thanks…I have found that website to be utterly indecipherable, and probably need to go on some kind of training course to learn MB-speak, but I’m grateful for you taking the time to try and help me :)
onefortheroad
uk.
It's all manufactured to a spec mercedes would of stated. It's ok to mix , I used a brand " comma " . No issues at all
Mine was a 2004 e320.
motocod
motocod
Devon
Thanks very much, I assumed as such.
motocod
motocod
Devon
Hi folks, finally managed to get under the bonnet and check the fluid. It’s red - can anyone tell me which type that is, please?
onefortheroad
uk.
Atf.
Put your reg into Opie oils .
That site tells you every oil / fluids your car will use .
Go along to the right , parts and everything else.
motocod
motocod
Devon
Thanks, that’s really useful to know, I appreciate it!
motocod
motocod
Devon
  • #18
Bought this stuff today…
Topped it off (used about 1/4 of the bottle) and it’s completely sorted. Smoother than ever, lighter steering, and completely silent. Very happy!
Thanks for your guidance.
Nik
mioba
Nottingham and Köln
Remove return line, lift front of car, lock to lock while filling - flush entire system. Steering will be heavenly.
motocod
motocod
Devon
  • #20
Just to add that since topping up the fluid (as shown above) I've done at least 1000 miles, and everything remains ticketty-boo.
Thank you to all of you that contributed.
