mshah70
Mercedes w211 2007 E220 Cdi
Hello
Owner of merc w211 e220 Cdi 2007
226k
I am having low fuel pressure issues.
Star diagnostic code 22e7
Check high pressure control ‘rail pressure too low’
When i open up the throttle (hard acceleration) going up a hill or on motorway, the engine light comes on and car goes into limp mode.
I used Star to check high pressure control, Quantity control valve, pressure regulator all sensors seem To be in working order.
I tested the low pressure circuit, fuel pump seems to be in working order.
Please i need some help.
When was the fuel filter last changed?
mattkh
England
A160 W168 1999 1.6
I used Star to check high pressure control, Quantity control valve, pressure regulator all sensors seem To be in working order.Please i need some help.
What was the fuel pressure reading on your test while going uphill ?
mshah70
mshah70
star
Reading
Smart + others :)
Check injector leak off.
mshah70
mshah70
I only checked the fuel pressure at idle
By connecting to fuel filter inlet
Pressure was just under 4bar
Also after a single initiation of the fuel pump, the fuel output was 700ml, which star said was ok
mshah70
mshah70
Can u guide me on how to do leak off myself, and where can i get the proper test kit
