W211 rear brakes replacement
motocod
Devon
W211 E270 2005, ex W124 300CE 1989
Hi Folks,
Im looking to fit new rear discs and pads on my 2005 E270. I assume I can disable the brake assist thing by simply disconnecting the battery? Otherwise it all looks quite straightforward. Sorry for such a basic question!
Thanks,
Nik
mersum1es
Finland
That's why aux battery is fitted in car :)
(Honestly can't remember can car pull isolation relay if ignition off, doubt it)
Some people disconnect SBC unit, but it theory if you put car lock, wait 15 min and put you keys safe inside the house (if KeylessGo), it should be ok.
SDS and some other diagnostic devices can disable SBC.
motocod
motocod
Devon
That all sounds needlessly difficult. Am I reading it correctly that my car actually has two batteries? I'd prefer to have everything disconnected before I go risking my fingers near the brake calipers!
onefortheroad
uk.
Yes 1 in the boot and 1 under the pollen filter. Right hand side in engine bay.
As for brakes you will most likely have to back off the handbrake to get discs off.
motocod
motocod
Devon
Great, thank you. You'd think, having owned the car for almost six years I'd know stuff like that. I guess it goes to show how reliable it's been!
Is the handbrake mechanism easy to fathom? It probably needs adjusting and lubricating anyway, as I don't think it's been touch since I've owned the car.
onefortheroad
uk.
You tube it m8. Theres a star wheel inside the hub you turn.
motocod
motocod
Devon
Nice one, will do. Good old YT!
pgh13
Nr Leamington Spa
E320CDI 2004 - straight 6 diesel
When I did the front brakes I disconnected the SBC multi easy connector. Less faff than anything else
motocod
motocod
Devon
Great idea, thank you, that sounds like the simplest approach. Where is that located, please?
pgh13
Nr Leamington Spa
On mine, when you stand in front of the car, it's by your left hip. It's a block with lots of 3/16in pipes.
I’m sure there is a lot on The YouTube if you search disabling SBC, or Mercedes rear brakes with sbc or similar
onefortheroad
uk.
Judging by the amount of questions I'd think having a garage fit your brakes is the best bet tbh.
Wearsafoxhat
Sunny Hampshire by the sea
This is the sbc unit, the plug is on the side. Not too sure where abouts in the engine bay yours will be but this is what one is. Adjustments.jpg
motocod
motocod
Devon
Great, thank you - that looks familiar.
motocod
motocod
Devon
I get what you're saying, but thankfully I'm not entirely inept. As a mechanical engineer of more than two decades I merely prefer to be prepared, so I don't waste time.
onefortheroad
uk.
motocod
motocod
Devon
That said, I had a look yesterday, and both sides look like they have at least 5mm of pad visible on the outer pads, so I probably won't bother.
That will last years :D
motocod
motocod
Devon
  • #19
I'm easy on brakes anyway - I don't really tend to go charging around in the car, and in all honesty I'm not sure I've ever replaced the pads on the back. I've owned the car almost six years now!
onefortheroad
uk.
I'm easy on brakes anyway - I don't really tend to go charging around in the car, and in all honesty I'm not sure I've ever Had the pads on the back replaced. I've owned the car almost six years now!
Inside pads will be around 3mm or less then.
