w216 CL63 AMG Command...am I doing something wrong?
Cipollini
Slovakia
w216 CL63 AMG 2008 w211 E270 CDI 2003
Hi all,
sorry if there's a similar question here already. I have just bought my dream car CL 63 and it looks like I am missing few things in the menu settings, e.g. advanced adjustment of seats and massage setting, which should be there according to the owners manual.
I am the owner for few days only so I don't know if I just can't find it. I only have the "lumbar support" setting in the car, and it probably doesn't work either.
There are no other seat settings or massage function in Command.
The car also has a rear view camera, but in the "Assistance" section under Speedometer, the Rear View Camera option isn't even there, so I can't turn it on.
Thanks in advance for all advices guys.
Crispian
nuneaton
W166 Ml63 AMG with performance package
I'd put your vin number into a vin decoder and see if it actually came with massage seats, it may be in the manual,but would have been an option.
C
Cipollini
Slovakia
VIN decoder says
432DYNAMICS SEAT, FRONT LEFT AND RIGHT
I´ve been told it should be massage seats, previous owner confirmed the massage function worked. Even if it´s not there should be many more seat adjustment in the menu.
But it´s not only the case of seats, I have rear view camera installed on the car´s butt and I can´t turn it on in the menu.
Mike Smith
Reading
2019 C200 Estate AMG line plus
Rear view camera only comes on when reverse is selected unless you have 360 cameras.
Ask previous owner to show you or tell you how to get massage seats working.
C
Cipollini
Slovakia
I tried to turn it on with reverse selected, but no success yet.
I asked previous owner about massage seats, but he said he didn´t use it.
To me, the car menu looks much thinner as it should be looking at the owner´s manual, or I just don´t know how to use it (coming from BMW iDrive)
Mike Smith
Reading
The camera should open automatically when reverse is selected.
However there is an option to turn it off in the Comand system, not sure if it's the vehicle settings or main settings.
Have tried searching on Youtube? plenty of videos on there for operating various features and settings.
C
Cipollini
Slovakia
Thanks. I haven´t, I´m just looking into my manual.
But I am sure the menu from 0:37 in the video I don´t have in my car. I can´t find it
C
Cipollini
Slovakia
This is newer Comand version, I have 08´ CL w216
Mike Smith
Reading
I thought it was the same from 2007 to 2014
C
Cipollini
Slovakia
No, I have slightly, but visibly different looking menu.
Mike Smith
Reading
Oh, ok.
Then I have no idea.
Good luck getting it sorted though.
C
Cipollini
Slovakia
Thank you. Will have to visit local MB dealer on Monday.
peterws1957
Lancashire
Massage function was an option on the CL63, didn't come automatically with Dynamic seat option, so your car might not have it. The massage function is Pulse Mode in Comand. Select which seat, turn dial, pulse mode appears, press and menu appears - it may be turned to Off, otherwise you can have 4 settings.
C
Cipollini
Slovakia
Thanks, I know but these seats should have more settings than lumbar support even without massage function. Lumbar support function seems not to be working anyway. In seats settings I can see only lumbar settings and when I turn dial, it automatically come back to 0.
C
Cipollini
Slovakia
Today I realized the trunk is only opening up to the roof height, so I tried to follow manual and search for trunk opening restriction setting.
Surprisingly (or not) this option is not in the menu. Weird, weird, weird...
This means there is a leak in the system.
If you press the seat button on the centre console, it should take you straight to the to the seat adjustment menu with pulse option etc.
Can you please explain this?
The seats use air to inflate bladders to do various things
if it goes from the setting back to 0, it means there is fault, usually its a leak, but also can be broken pump, faulty valve etc.
C
Cipollini
Slovakia
  • #20
Thanks, that makes sense.
But I don’t get why there are missing settings like trunk restriction, rear view camera etc.
www.ckinsurance.co.uk
