Number_Cruncher
- Oct 10, 2007
- 1995 W124 E300D TE
Be careful if reducing the rear tyre pressure against the front ones as that will alter the slip angle so will give the car a tendency to over-steer, as opposed to the safer design specification of gradual under-steer.
Hurrah!
As you know I've been banging this particular drum for a long while, and it's really heartening to read someone else writing it up.
I fully agree that the difference in pressures on car tyre pressure specs is very important, and it should not be erroded.
If the car's wheels are all the same size, the correct way on MBs to avoid the problem is to rotate the tyres. The fronts will tend to wear their edges, and the rear tyres their centres - swap them over every now and again, and the wear will be shared out, and you'll get longer total tyre life. Tyre rotation is a part of the MB service schedule that seems to be missed out or disregarded for some reason.
