bigt
- Nov 7, 2004
- Location
- grimsby ne lincs
- 190E, E300, Vito 110 CDI, ML270
Definitely worth checking battery voltage, as mine was doing strange things with warning lights as the alternator slowly died. Put a multimeter on the battery with the engine off and after car has been parked overnight. If it shows over 12.2 you are ok, if lower borderline - if a lot lower, could be battery is on the way out and causing your problems. These cars are very voltage sensetive.
hth
trev.
hth
trev.
