What is this Socket ?
amkahal
Lebanon
E230 Avantgarde 1997
Hi, I found this socket not connected near the projector lights from the front bottom of the car (W210 E230 1997 Avantgarde), so what is this for ?
A
amkahal
Lebanon
  • #2
176 viewers and still counting :) is this plug strange that much ?? ;)
Yes I have no idea :(
brandwooddixon
Wolverhampton
S63 Coupe 2014
What colour is the wire that it is connected to?
What size is it? (Dificult to tell from the photograph).
It looks as if it has a seal around it, which would imply that it is plugged into another connector end or some equipment.
spock500
Milton Keynes
300TD, 1998
The question is does everything work, fog lights. headlight washers and so on?
star
Reading
Smart + others :)
Looks like the connector for parking sensors ??
A
amkahal
Lebanon
Everything is working, lights, fog lights, washers, etc... But my is this model have parking sensors, i dont think.
Where does the lead/cable go to
MissyD
Essex init
www.depop.com
E200 1993, E300 Coupe 2019
The picture is very close, maybe one a bit further back would give a better clue.
Jay Gee
N.Wales
Honda
The wiring loom may well have the connector,even though the option is not on the car.It would surprise me if MB custom made a wiring loom for each and every car. Got my parachute ready if/when I get shot down in flames!:lol::lol:
Xtractorfan
S class
It looks like a washer jet pump ....do you have headlamp washers...also a 2p coin or similar in the pic would help with size /scale...
spock500
Milton Keynes
300TD, 1998
Sometimes the wiring looms contain plugs for options that may not have been added at the factory, perhaps this is the case here?
edit; I have just seen Jay has posted similar solution. I must be a slow writer, took me 3 minutes to write one line, lol
Frontstep
T210 320cdi
Looks like one end of a brake wear indicator sender unit too me.
A
amkahal
Lebanon
thanks guys for your efforts, i'll post a new picture asap.
A
amkahal
Lebanon
this socket has code: 1405403381 , so ??
bigtwin
Banned
Do you have cruise control fitted? If so, this is not used. It's the connector related to the throttle idle.
A
amkahal
Lebanon
  • #19
logic, because my cruise control doesn't work, so where is right place to connect this ??
