Wheel bolts torque settings.
DREAMER NO2
W124 2.6E M103 1989
good info
Television another good post for you there .I was looking , as i have removed the first one from the car to refurb by hand. Not to bad realy the reverse was better than the front.It had been washed so many times only primer coat showing in places. Thanks again.
S.Speed
Lancashire
Older Citroen Now :-(
  • #67
What size bolts will fit mercedes 10 hole alloys on a 1997 w202
As Simon but the length of the M12 bolt will depend on the wheel fitted, the bolt length is important as too long and they will foul the parking brake shoes.
darkchild101
Edinburgh
C250 TD/1997/2.5litre
  • #69
Sso is the centre bore the length of the bolt?
The center bore is the diameter of the actual hub that the wheel fit onto, the wheel bolt length depends on the wheel fitted and they can be different
  • #72
TV are you sure about the same value for both steel, and alloys. Alloy is softer than steel.
Re normal tightening then yes, just the 1 figure given in WIS
rodisi
Germany
E220CDI 1999 W210
The forum never fails me. I'm doing a service on my car, just checked the brakes and putting on the wheels, of course, I forgot the torque. Did a search on duckduckgo.com for mercedes wheel bolt torque and bob's your uncle, I'm in this thread.
Thanks.
Alex M Grieve
Broom, Warwickshire
Thanks.
Always good to get it on the correct thread before applying the torque. :rolleyes:
ajlsl600
france
Ft lb and thou for me as well when on my mill or lathe I have to think 2x for metric, I reckon I can see 2c thou comming off! 1000 in inch far easier for crusty me n that how I was trained
www.ckinsurance.co.uk
