Garista
- Apr 29, 2018
- Location
- France
- 2001 ML 270 CDI. 1991 R129 300 SL
1991 300SL r129. Hello;
I have been having problems with the wiper not working and now the indicators are also not working, the problem has been intermittent but now not. I have been following the advice on the blogs up to this point.
The lights are working and I recently installed a new febi combination stalk, which solved the no headlights problem which I had, but this is new. There is power to the wiper motor when the ignition is on and the wipers are switched on. I took apart and cleaned the wiper disk mechanism with the sweeping electrical arms which were all black and greasy. I also then cleaned inside the wiper electrical motor which was really filthy. It has carbon brushes which are ok. Then I bench tested it with 12V and it worked. I put it back in the car.
I cleaned and lubricated everything and tested it with ignition on, but although it is getting electricity to the wiper, the power seems to be too weak in the car to move it. In fact at the fuse it seems weak to begin with, not 12 V. The battery is good. Why not enough power at the fuse? This has stumped me a bit and I wonder if anyone has any advice.
