Hi ; My ML270 ( 2005) has windscreen washer problems. They will not move under their own power , but do when I give them a hand ! the fuse is OK. Do I need to replace the motor or is there a mechanical issue? Can I get a second hand motor fitted?
Hi.
They are known for getting wet inside, hence have dodgy connections,and start to seize up.
Remove wiper arms, you may need a removed tool for this, remove rubber trim along front of scuttle, two plastic nuts either end and then fiddle the scuttle grill out, it takes a bit of fiddling. Then remove lower cover which will reveal wiper linkage. Four ten mm bolts hold it all in, linkage comes out with motor in plug the wiring.
Either refurb what you have or buy another proved working unit.
Mercedes-Benz Servicing, repairs, engine and diagnostics Wayne Gates - Mercedes-Benz, Unit F3, Phoenix Industrial Estate, Rosslyn Crescent, Harrow, Middlesex, HA1 2SP Tel: 020 8863 9233 Established for 20 years all vehicles washed and vacuumed.
