1999 S210 220CDI Limp home
GForce
Norway
Various E&G Class
Esteemed posters,
I turn to this forum for help with a problem I cannot shake;
Every morning when starting the car, it will have an ABS warning, and if driven, the transmission won't work. It sticks in 3rd gear and the speedometer does not work.
If I turn the ignition off and remove the key (a few times), it will eventually start with no warning lights and everything will work!
A diagnosis showed the message: ABS control unit error, so I replaced it, to no avail. I have also checked various ground connections and replaced the brake pedal switch (after being advised to do so).
At first I also had a message indicating problems with the RR ABS sensor, and the car would stop shifting, but that was remedied by connecting the sensor(!!)
Has anyone heard of this before, and is there a cure??
Thank you!
Kind regards,
Bard Thomas
toby1
West Berkshire
1997 SL500 R129
Worth checking battery voltage - too low and it will put the gearbox in limp-home mode. I had this after leaving the car for 4 weeks last winter
G
GForce
Norway
Various E&G Class
I have put a good battery in it as someone suggested that could have something to do with it. I have also measured the charging voltage, and it is as it should be, according to the workshop...
