shaileen
Hi all,
Apologies for another thread about this issue but I just want to know if there are likely to be future problems once this is fixed.....
I have a problem with my timing chain. The car wouldn't start one morning and after having it towed to an garage, it was diagnosed as having a loose timing chain and worn sprockets. The chain had slipped off and in the process destroyed half the engine! Cost to fix £3-3.5k!
Apparently this is down to wear and tear, even though it's only done just under 75,000 miles and I've just been very unlucky. The car has been serviced as per schedule but from reading around, MB doesn't want to take responsibility for this and it's down to the owner to sort out. Anyway, I've given the garage the go ahead to fix as I don't really have much choice in the issue.
My question is this:
Is there anything else major likely to go wrong on this car (i.e. should I be looking to sell it asap and at least try to recover some of the expense) or should it now run fine for the next 50,000 miles or so? I believe I read something about a problem with the automatic transmission but can't seem to find it again.
Any advice would be appreciated.
Thank you.
Thank you.
