2010 W212 E350 CDI OM642 - cooling fan running
jeremy156
Bordon, UK
W202 C200 (1999)
Hi all,
I'm sometimes noticing that the radiator cooling fan is running at the end of a run when I wouldn't expect it. I don't know whether it's running throughout - I just notice it as I slow enough to hear/notice it.
This has been on perfectly normal warm-ish days (16-18 degrees C) with a normal speed drive giving plenty of airflow. I'll arrive onto local roads and wonder why there's so much noise - to discover the cooling fan is blowing hard.
Coolant temperature looks to be normal.... so I wonder what I should be looking at to determine whether there's a problem. Any thoughts?
These are coupled to the aircon, its quite normal after a run for the fan to run or even start up on its own when turned off.
jeremy156
jeremy156
Bordon, UK
W202 C200 (1999)
Thanks Malcolm - I had a feeling I'd be worrying about nothing :)
paul_f
The vehicle will have been part way through a DPF regeneration, so the fan is used to then cool the engine bay down
jeremy156
jeremy156
Bordon, UK
W202 C200 (1999)
I like worrying :) Gotta care for your loved ones - metal or otherwise :)
