Auto Stuck In '2nd' Gear
Frankie Soundman
Ireland
Sprinter 318 Auto 2007
Sprinter 318 Auto 2007.Van starts as normal,put it into D and van moves but won't get above '2nd' gear.It just makes the revs get extremely high.Any help would be appreciated.The battery did go dead before this happened,would this cause anything?
Thanks :confused:
bob 6600
Audi S8 V10, S210 E320 CDI (R.I.P.)
Sounds like gearbox plate. Have you had any codes read /cleared?
Sent from my Nexus 7 using Tapatalk 4
If you started the VAN with a low battery that is cranking volts under 10 volt then the gearbox ECU cannot set correctly.
F
Frankie Soundman
Ireland
Hi guys,
Thanks for all your replies.Van is currently in the garage.I haven't spoke to the mechanic properly yet as I'm out of the country but he reckons it might be a sensor?
Steve@Avantgarde
Bristol/Somerset
Have seen this happen when the reverse light switch malfunctions - safety default. Check your brake lights.
Reverse lights are controlled by the selector module. It doesnt have a reverse light switch. So it wont be this.
Would need the fault codes to give a better guess at what it might be.
oigle
members.optusnet.com.au
Sorry - Stuffed that up. It was to do with the brake light switch, not the reverse. I DID say "check the brake lights" so obviously I got myself confused...Created exactly those problems. New switch and all was well.
F
Frankie Soundman
Ireland
Hi guys,
I'm still waiting for the codes but my mechanic has ordered a gearbox module.That is what Mercedes in Germany said the problem is.I've also found out since that after my battery went dead the van was started with a booster.Would this have damaged the module?
F
Frankie Soundman
Ireland
New module fitted and van is 100%.Thanks for all you help and replies.
Safe driving :)
Tel: 020 8863 9233
