Automatic gearbox problem
RhysMT
New Registration
A170 SE CVT Automatic 2006
I've got a 2006 A170 that sometimes won't select drive (if I'm stopped) or slips out of drive into neutral at low speed - has anyone have an idea what is happening, and if it will be expensive to fix?
Thanks in advance,
Rhys
Assuming this is a proper automatic and not the semi automatic 2 pedal manual gearbox it could be low pressure in the gearbox hydraulic system. How many miles has it done and when was the last transmission oil and filter change?
ZZZZ
It's a CVT Alastair - they dropped the silly clutchless box with the end of W168.
Rhys, it is most likely what LostKiwi said above - get the ATF and filter changed, and check your service book - it was supposed to be done at 37.5k miles or 4 years.
I was advised to do the transmission oil change every 35-40k miles (same year, same CVT as yours), rather than just once at the mileage above - I had the first one done recently and am going to follow this advice.
Also, when you start from cold, do not shift into gear, until RPM drops below 1000 - this is from Des (aka Forrera) - he does almost exclusively W168 / W169 and has a wealth of knowledge on these models.
