Central Locking Problem & removing door pannel W211
martin828
New Registration
Salisbury, UK
A class
Hi, I've just got exactly the same problem on my A Class, where the passenger door central locking knob is jumping up-and-down really fast. It's really annoying because it tries to lock itself as you gather speed. I realise it has something to do with a spring inthe motor but what exactly do I need to do to solve it. If you have anything, i.e. diagrams please can you send them to martin.fildesAyahoo.co.uk A=@
Thanks, martin.
Thanks, martin.
Is this a 168 or 169 please
About one hour I would think
Jsuki06
New Registration
UNITED STATES
Eclass/2005/3.2L
Lock acting weird
I have sent the details and welcome
I also am having the same problem with my E-Class w211 E320 and the front drivers lock is going up and down several times and sometimes doesnt unlock at all and it sputters so and when I took it in to the dealership they said it was a 450$ fix so I wanted to try myself because it still works just very inefficiently! THank you if you do help me because I am new to the forums!
Jsu
Jsu
Hello and welcome to the forum,, I just need an Email address please
repvik
Trondheim, Norway
'04 S211 220CDI
Does anyone have a time estimate on replacing the part btw?
Took me about three hours. Most of the time was spent drilling out the two blind rivets and wiggling the old lock mechanism out and the new one in. I wasn't in a hurry though.
BTW, I tried opening up the old mechanism to see if it could be fixed. The problem appears to be a special spring that eventually breaks. I doubt this spring can be bought, so the only solution appears to be to replace the whole mechanism. Mine has survived 7 years/380000km, so I'm not exactly surprised it broke. ;)
ELGRINGO
fylde coast
e230 c180 sl280 brabus a190 smar cart
Not like they use to be! how many locks do we seem to be changeing, since whent from vaccume 203, 209,211, not getting any better.
kociboss
New Registration
W211, W220
Hi Malcolm,
same problem here. Please could you send me more info to try to fix this spring.
kupe@abv.bg
Thank you,
k.
scarf
Sofia,Bulgaria
e320 CDI 2005
Hello.I have the same problem with left door ....the car is W211 2005 ...my car have keyless go...and I cant lock and unlock ....please....give me some help...my email is scarf@abv.bg Thanks
So sorry I cannot always catch up on all post :(:(
Both info sheets sent to you
pavakhtar
Hi Malcom,
I got the same problem with the central locking for my W211, could you help me?
Hi pls could u send me how to remove the door panel and lock mech papers as I also have problem with my passenger door lock thanks alot
Developer
S212 E63 S 5.5 biturbo
When the instructions ask you to remove the cylinder lock (worded something lke that), pull off the rubber door seal and insert a tork bit through the hole to undo.
Once again I need an Email address
