central locking
benlawyers
Southampton UK
CLK 240 Elegance (2002) '52
The passenger door on my CLK 240 doesn't open from the outside even though the lock is in the "up" position. Before i take the door panel off and look at the mechanism is there a known fault that would cause this ? (it opens fine from the inside handle?
It will be stuck and require some lubrication, use a PTFE product or Silicon, that really last well
B
benlawyers
Southampton UK
thank you for your response. the catch comes up and the handle pulls but the door doesn't open. it doesn't seem "slack2 enough for it to have become disconnected from the mechanism. Is your solution still the right one for this and where should the lubrication go? would WD40 be suitable if it is the case?
There is a spring loaded plate that has not returned, and it is this that needs to be lubricated or checked.
Wd40 is not the best long term solution, but it could work... the door car will have to come off and maybe the lock lowered
B
benlawyers
Southampton UK
thanks mate ... ****** hell !! didn't really want that hassle but hey needs must etc
That was a typo the door card it should have said,,, I have the instructions if you would like them
B
benlawyers
Southampton UK
yes please ... thank you and i'll let you know how i get on
Email address please and you can remove it in edit
And sent, you can edit out the address
B
benlawyers
Southampton UK
thats terrific ... thanks ... and one more thing !!! passenger side heated seat not operating .. no LED's lighting up not sure yet if the seat's heating or not as as soon as i saw that the LED's didn't light i left it alone. is this a usual issue?
Not sure on that seat fault, this does sound like controller rather than the seat pad, but I am not sure on this one
B
benlawyers
Southampton UK
your help has been great Malcom thank you. i'll post my other problem separately
www.ckinsurance.co.uk
