ajlsl600
france
Before removing, replacing ANYTHING in there have the area blasted out, clean. Dry dust, compressor, caked mud, pressure washer. Get urself an exploded diagram of it before dismantling, you can get seal kits.
C
cl500:/
Leicester
Cl500
  • #65
You reckon I should just get seal kit instead of a refurbished valve block? The area is pretty clean, cleaned it yesterday when I was testing the inlet pipe, I don't know where to find the diagrams lostkiwi was kind enough to send some
C
cl500:/
Leicester
Cl500
  • #66
Hi all, you wouldn't believe what Mercedes told me, I live about 5 minutes away from the dealer so I just wanted to check the prices for the rear valve block and the sensor.
So they told me the rear valve block is £1800 and they don't sell the sensor separately they sell it with the unit for £800
I did get the part number. Although lostkiwi gave it me anyway its the same
And for the electrical connector they don't sell I went to all the local scrap yards and none have it so I think I should get one made maybe if anyone can find me it I would appreciate it thanks all
C
cl500:/
Leicester
Cl500
  • #67
Hugeee update so basically that pressure sensor that had a dodgy job doing was the culprit for everything I looked at a few pictures online showing the way the wires are supposed to be so someone put the ground on the wrong pin so I got my soldering iron and removed the ground and 1 of the 2 live wires and switched the places I then went ahead and re soldered it back together ( I will buy a proper connector and a new sensor once I find the connector) then I left the car running I could hear a hissing sound then I let it run for about 30 minutes to 45, and keeping an eye at the reservoir I then got a bike pump unscrewed the face of it and put it where the dipstick goes it sat perfectly on it I pump few times made sure not to over do it, nothing happened I then waited for my mates scanner just got it at 5.45 connected it the pressure dropped significantly from 255 to 96bar I then tried the buttons nothing working still red abc I theennn pumped and the pressure didn't increase so I tried my luck and did a level calibration at high speed where I can lift each side separately did the fronts they finally go up and down then I tried the rear I heard alot of air like alot then after my 3rd or 4th try at lifting the rear left nothing so I dropped the front left then lifted the front left then the rear right went up I got soo happy then I tried the rear right and it went up now they all go up and down with the scanner and no leaks underneath certified mekanik now I am almost out of petrol so will get a Jerry can and fill her up with v power £50 for now to try the buttons in the car, and to see if the warning has gone
I'll still keep everyone updated
Turned out I didn't need the valve block and it was my mistake I missed the point lost kiwi told me to check the pressure sensors that's my bad we learn i guess, I don't know how to thank you all with the information provided by all the lovely members( I still need to go to the mb specialist to clear the codes my mates scanner doesn't want to do it unfortunately.
Will upload a picture or two
Thank you all so much really I appreciate it all
C
cl500:/
Leicester
Cl500
  • #69
If you fancy a drive to Daventry I can clear codes no problem.
Got no mot or tax so risking it, taking it to the mb specialist he's about 10min away and will do it for free, one of my uncles mates but doesn't want to take on the job when I asked him
But I appreciate the offer thank you, your only a 45min drive away from me maybe if something else comes up with the car I will let you know much appreciated though its been almost a month since i started this conversation and the amount of help you helped me with lostkiwi cant thank you enough much love for all the help, even to all the others thank you
Thank you all will let you know if the car goes up and down from the dashboard not the scanner hopefully it does
C
cl500:/
Leicester
Cl500
  • #70
Won't let me upload some pictures says file to big, so tomorrow I will go to the mb specialist he's will try to calibrate it I did notice that the abc warning would go on and off I need to re solder it properly maybe but it went for now got no abc warning but can't lift the car up or down with the buttons for some reason and whenever I switch the car off the front left would drop slightly if not more don't know why but will get it checked with the guy tomorrow
Screenshot the pics on your phone, then upload the screenshots - that should make them a manageable size for the forum.
C
cl500:/
Leicester
Cl500
  • #72
Here are all the picture thank you blobcat
C
cl500:/
Leicester
Cl500
  • #73
Any body know if these part numbers are compatible because I asked a fb group and they just sent me a whole bunch of part numbers thanks
A2203200858, A2203270215, A2203200558, A0125429217, A0035422018, A2203270231
They aren't all the same part. The two ending 58 are complete valve blocks, the one ending 15 is an accumulator the ones ending 217 and 918 look like pressure sensors and the last one is also a valve block.
Use the sites I gave you earlier. If you put in your vin number they will tell you the correct parts and alternative numbers
ajlsl600
france
Strange that, rodents ate the wire, right at plug on my rear valve block. Benz dealer here had no prob selling me 2 plugs with 4 inch tails to solder, shrink wrap into my harness. In Nice little mb bags as well so not aftermarket??
C
cl500:/
Leicester
Cl500
  • #76
Well here they told me no can't do which location is your benz dealer if its not far I will give them a call
C
cl500:/
Leicester
Cl500
  • #77
Also here are the items that came up when I searched with those part numbers
ajlsl600
france
Carantan France 40 min south of cherbourg
ajlsl600
france
U cud Google it and have them post. Or at least get pt nus if I get time in next few I will look wis see if pt nus there
