ajlsl600
france
ajlsl600
france
Try this outfit
ajlsl600
france
No idea but lots of fighting around this area in ww2 germa s flooded a lot of Carantan area, I seem to remember?
C
cl500:/
Leicester
Cl500
  • #87
Yep that's what I said. The 58 and 231 numbers are valve blocks as you found.
But are the sensors all the same so if I buy that first image one and remove the sensor and put it in my car will it work?
Why put in a second hand sensor of unknown health and unknown part number?
C
cl500:/
Leicester
Cl500
  • #89
My connector is broken on my sensor and it keeps flagging the abc it goes on and off so I need another sensor I won't be buying a new one for £800 they are different part numbers all of them are:
A0035422018
A0035422018
Don't know where you're getting £800 from.
Genuine part new and in stock.
C
cl500:/
Leicester
Cl500
  • #91
C
cl500:/
Leicester
Cl500
  • #92
Hi all just finished fixing the Mercedes bought one of the items from eBay and connected the sensor the seller provided the connector with the wiring I soldered it all together and now the car goes up and down from the dashboard
Thank you all for the help
Much appreciated
dldb
CL500 (C216) 2009 107K miles 5.5l V8
Nope I used a different brand I used this one mannol
I know this is a late reply but worth recording that Mannol oil is good stuff. Notice it is says MB 345.0 which is the same as the Fuchs. It would not be causing a higher pressure.
www.W140.co.uk&www.r129.co
