Costs associated with S320
R
romik
Ipswich
S320 CDI/2005/3.2
  • #22
So far I have decided that I need to get the w221 model. Working on the basis of getting 2006 plate. I have considered getting the 350 petrol version instead of the diesel one, looking at the mpg of both engines, on a run of 1000 miles petrol would require £30 extra in fuel, if that's the case, on an average run, then I can live with that. Hopefully, 350L hasn't got the issues that diesel engine has. Perhaps Alex can advise me here.
You must check that the engine is the modified one, I have the serial number somewhere
R
romik
Ipswich
S320 CDI/2005/3.2
  • #24
Could you explain please, which modification are you talking about?
The only big issue we see with the 272 engine (V6 petrol in 2006 car) is the timing gear wear, I have an ML350 coming in tomorrow for that job, and it is a biggie!
There is a post here giving the serial number of the modified engine
this was the number I think 468993
R
romik
Ipswich
S320 CDI/2005/3.2
  • #27
How much does that cost?
R
romik
Ipswich
S320 CDI/2005/3.2
  • #31
Warranty Direct
Just had a quote from Warranty Direct for an S class, came in at 650 pounds. Have never dealt with them. Is that something worth considering?
Many use them, there are threads running on this subject it you look
st4
Banned
Sunny Scotland
Disqualified driver
Most of the diesels are ok. Not perfect engine but doable with a decent indie.
R
romik
Ipswich
S320 CDI/2005/3.2
  • #35
This being my first high maintenance vehicle on top of uncertainties linked to starting a new venture whatever vehicle I decide to go with I think I really need to look into a good warranty, as long as the cover is appropriate for the usage of that vehicle. It seems to me that whatever the engine w221 has issues, expensive ones.
tode
NW FRANCE
S350 btec 2011
I think that if you spend too much time reading on here , then you'll talk yourself out of buying any Mercedes :D
I've had diesel MBs for about 30 years now, and never had any problem.
They are good cars.
The customers will appreciate them.
Yes, you must plan for yearly maintenance costs.
If you still can't decide between petrol/diesel, then just have a look at Mecedes taxis, and see how many there are of each: there must be a good reason why 95% are diesel, all over the world. ;)
R
romik
Ipswich
S320 CDI/2005/3.2
  • #37
They are good cars.
I think it's reasonable to conclude that a diesel lwb w220 is a good choice considering my situation with a warranty.
Yes it should be:D:D
MBDevotee
Bristol
Dreaming of a CL55k - one day maybe....
Or get a S500 and LPG convert it - have run 2 Mercs on LPG - NEVER had a single problem with either related to fuel or engine (electrics can be more of an issue).
Diesels I have had 1 and already had some problems - reading on here they seem a lot more troublesome.
R
romik
Ipswich
S320 CDI/2005/3.2
  • #40
Due to high estimated mileage, I am leaning towards original configuration, but with an extended warranty.
