- Mar 14, 2005
- Age
- 89
- Location
- Daventry
- 2002 SL500, 216 CL500, all fully loaded
Got voltages from back two wheels near enough identicle, only rear right hand wheel sets the lights on. Code fault being right rear. When running the car with left rear wheel up off ground when you blip accel traction control kicks in properly. There is a brake pad wear indicator cable but not connected to pads, my last merc was like this n caused no probs but just checking, getting desperate!!
Stating 'reduced pressure' in code wouldn't mean I needed to bleed the pump or something? Calliper fault?
Callipers cannot put the warning on and the pump is not active till the pedal is pushed
