Hi All,
Hoping someone can help please.
I purchased a 2007 SL and have noticed water in the boot.
I have checked the regular leak points and it is NOT the C Pillar and all seals are in tact. All drains clear and working as expected. All carpets are dry.
There is a set of wires that run behind the battery and these wires are covered in a cloth ducting. These wires travel up behind the trim towards the fuel cap side of the boot. The cloth ducting is soaked and very wet and as a result the water is dripping from the cloth ducting into the boot well.
Any ideas/ remediation as to how this issue would be gratefully received.
I have attached a picture with the set of wires that are wet circled in red.
Thank you all in advance.
