vincentfishing
- Oct 31, 2019
- ML270, 2003
- Thread Starter
- Thread starter
- #141
yes same mirror, same trim, no lock, so hopefully straightforward,if its the same electric mirror (type with indicator in) it should fit and work. I do not think the passenger side has a door lock (stand to be corrected) meaning a key access. If it does not, do not think the door solenoids would be a programmed thing, however, cant be that difficult to swap them over. You will have to do the door trim i suspect, or maybe not if identical to yours.
If you are painting the bumper with rattle cans, you could try plastic welding with a soldering iron ?, practise on old bumper first perhaps.
saw a video on soldering iron to weld , so an 'alternative'
