My new CL203 goes in limp mode and has errors
david92
essex
2007 C Class Coupe 220 CDI
Hi there,
This is my first post here so be gentle :)
I have recently purchased a CL203 (c class coupe 2007 220cdi) and it goes into limp mode occasionaly, more noticably when i go into reverse rather than drive from cold start (work car park).
I have had codes read from a friend with a delphi kit.
The codes he got were as follows:
2509 heater booster control module
2632 charge pressure regulation
2359 boost pressure: high pressure
I have read that the Cdi engines have common faults with the turbo actuators but im reluctant to go down that route if it could be something else at fault.
I know these forums are a fountain of knowledge and any help would be much appreciated!
Thanks in advance
Flyinspanner
Ruislip
I think to diagnose fully, you need to find a good local independant with a proper STAR.
It can interrogate the systems 'deeper', so you don't waste £ changing stuff which is actually ok.
sineda
East Midlands
Mercedes B180 CDi SE
I went with a guessing DIY way and bought a MAF although this wasn't the problem. Took it to a local MB garage who diagnosed the car properly using the right tools and immediately (in under an hour) they've located the fault as being a split pipe that connects to the EGR. Conclusion: get it properly diagnosed before spending your monies.
Sent from my SM-G925F using Tapatalk
Craiglxviii
Cambs UK
+2 and take it from someone who has a CL that has seen its share of issues ( yours is a C class- very big difference when it comes to things going wrong!)...
You need to get a proper fault finding & diagnosis done.
I had a limp mode. Reading codes suggested MAF most likely culprit. Changed it- no difference. A day spent with two members on Star- no difference.
Take it to trusty independent garage- anti knock sensor required replacement (actually the fault code showing, duh! But these NEVER go....!) so inlet manifold off and hey presto- a dead family of mice discovered in the valley between the cylinder heads, mouse wee had killed the sensor and rusted out the core plugs!
So pay £50-60 and get an Indy to diagnose the issue. It's worth it.
sineda
East Midlands
Didn't know CLs ran on mice power :D
But on a serious note, that's crazy how the found a mice there.
umblecumbuz
Wales and Gozo
.... so inlet manifold off and hey presto- a dead family of mice discovered in the valley between the cylinder heads, mouse wee had killed the sensor and rusted out the core plugs!
A right tail of the unexpected!
Umble
SL Koluwa
London, UK
C220 Coupe CL203
Hello David,
I can see this was 2 years ago thread
Did you manage to get it fixed? Do you still have the same car?
Rgs
Gam
Hello David,
Rgs
Gam
David hasn't been on the forum since 2017 buddy , so don't hold out for a reply .
Welcome to the forum though
